Reversed Pitch on Devo 8S
29 Mar 2013 22:14 #8257 by Gerhard_H
Reversed Pitch on Devo 8S was created by Gerhard_H
Hi !
I use to fly helos like the big ones with reversed pitch - climbing when pulling the stick.
I already own some other transmitters, two 2801, a DX-7 and a J6 (Nine Eagles). On each of them I swapped the throttle potentiometer connections, some had to be soldered, some were plugged.
OK, now I am in two minds how to process with the Devo 8S.
I already had tried two solutions :
1. Reversed throttle in the throttle channel which enables to program "normal" throttle curves. But every time I switch the radio on it is nagging that throttle is on 100%.
2. The other way is to program "reversed" throttle curves without getting the nagging mentioned above. But I don't like reversed curves.
So I think the only satisfying way is again to open the radio and swap the potentiometer connections.
What would you suggest ?
tia
Gerhard
29 Mar 2013 22:59 #8262 by DarkWolf
Replied by DarkWolf on topic Reversed Pitch on Devo 8S
Try going into the Model setup screen..
(click the heli icon->arrow right)
Where it says Model Type: Helicopter, click the word Helicopter.
There you can set up the swash type, inversions and mixes.. Though truth be told, I'm not sure what inverting those do.. So take what I say with a grain of experimental salt. :)
30 Mar 2013 05:08 #8266 by vlad_vy
Replied by vlad_vy on topic Reversed Pitch on Devo 8S
Gerhard_H wrote: Hi !
At your model file 'modelX.ini'
[safety]
Auto=min - change to Auto=max
30 Mar 2013 07:45 #8268 by Gerhard_H
Replied by Gerhard_H on topic Reversed Pitch on Devo 8S
@vlad_vy
Thanks a lot !
But that opens another question - how to edit the ini-files comfortable. Using the Windows Editor offers a quite curious stuff.
@DarkWolf
Seems to be another way to go, but I would like to avoid reversing operations inside menus wherever I can. Think I'll open the radio.
Regards
Gerhard
30 Mar 2013 08:03 #8270 by Gerhard_H
Have just found that the ini's really seem to be simple txt-files.
30 Mar 2013 09:04 #8272 by vlad_vy
Will be better to use any UNIX style text editor
www.deviationtx.com/forum/3-feedback-que...con-in-ini-file#6344
30 Mar 2013 14:45 - 30 Mar 2013 14:57 #8286 by Gerhard_H
Thanks a lot for that useful link !
Regards
Gerhard
edit :
Opened the radio and swapped the throttle-potentiometer connectors. Now I can use "normal" ini-files.
At this occasion I swapped both D/R switches with T/H and Flightmode so I can reach Throttle-Hold and Flight-Mode-Switch much better
Last edit: 30 Mar 2013 14:57 by Gerhard_H.
30 Mar 2013 15:26 #8290 by DarkWolf
If I could suggest a really good editor to use, consider Notepad++.
notepad-plus-plus.org/
It's Linux safe, multi tabbing and very useful, indeed.
30 Mar 2013 18:46 #8307 by RandMental
Replied by RandMental on topic Reversed Pitch on Devo 8S
DarkWolf wrote: If I could suggest a really good editor to use, consider Notepad++.
+1 on this, it doesn't screw up your ini files
Time to create page: 0.498 seconds
