Screen Backlight and on Devo 8S
- Gerhard_H
29 Mar 2013 22:22 #8259
by Gerhard_H
Screen Backlight and on Devo 8S was created by Gerhard_H
Hi !
How can I manage the screen backlight lasting a little bit longer ?
And - when the screen switches off I have no indicator (led or something else) that the radio is ON, that's irritating.
tia
Gerhard
tia
Gerhard
- DarkWolf
29 Mar 2013 22:39 - 29 Mar 2013 22:41 #8261
by DarkWolf
Replied by DarkWolf on topic Screen Backlight and on Devo 8S
You can hit the ENT button to bring the screen brightness back up.
Backlight can be set up via the wrench (top left) under transmitter config. Scroll down on that page (or hold the DN- button) and you'll see it.
Backlight: brightness
Dimmer time: how long till dimming (up to 2 minutes, disable down to 0)
Dimmer target: how dim it sets it
Far as not being able to see if the TX is on, the 8S has a red LED behind the Devo-8S tag that's quite bright. No?
Last edit: 29 Mar 2013 22:41 by DarkWolf.
- Gerhard_H
30 Mar 2013 07:35 #8267
by Gerhard_H
Replied by Gerhard_H on topic Screen Backlight and on Devo 8S
Thanks, DarkWolf ! I'm sorry I hadn't noticed the scrollbar; but later when I read the manual again I had found that issue.
Concerning the red LED - there isn't any, definitely. But I intend to open the radio next time so I can take a look after it.
Regards
Gerhard
Regards
Gerhard
- Gerhard_H
30 Mar 2013 14:49 #8287
by Gerhard_H
OK, have had opened the radio. But couldn't see anything because I didn't want to remove the whole board.
- DarkWolf
30 Mar 2013 15:40 - 30 Mar 2013 15:40 #8293
Replied by rbe2012 on topic Screen Backlight and on Devo 8S
In the Devo8 there is a red LED beyond the logo. To get there you have to open the tx, remove the transmitter module and the main board. You will find the LED at the back side of the board.
I am quite sure that it will be the same in a Devo8s.
Last edit: 30 Mar 2013 15:40 by rbe2012.
- RandMental
30 Mar 2013 18:42 #8306
by RandMental
Replied by RandMental on topic Screen Backlight and on Devo 8S
I have a silver Devo 8 upgrade to an 8s with the RX module, it's about 13 months old, it has the red LED. I bought another Devo8s (the Darker titanium colour version) about 6 weeks ago, it has the same LED behind the Devention label.
If yours has none or are not working, I guess you might have an even older Devo8?
- DarkWolf
30 Mar 2013 21:31 #8311
by DarkWolf
Well, he said 8S, so it shouldn't be that old? I think it may just be a factory defect or something. I've never ever owned a TX that did not have some kind of LED to state the power was on or not.
Time to create page: 0.285 seconds
- Screen Backlight and on Devo 8S
