Binding W/Rx2627H
- HeliIntervention
30 Mar 2013 14:42 #8284
by HeliIntervention
Binding W/Rx2627H was created by HeliIntervention
Hi Everyone,
First I would like to thank everyone who has contibuted to this great project!
I have loaded the latested nightly build after poking around in the previous release. I am having trouble binding in 2801 mode to a GCP Rx2627H. I must be missing something simple. It appears that it has to be in a Fixed ID to Bind. Is this correct? Rx just blinks no matter what order the Tx or Rx are turned on in. 7 second bind no results.
Also can someone help me fix my screenname it should read as HeliIntervention. I would be so grateful to have this fixed. I had a
(hell) of a time figuring out my login name.
Thanks. I am looking forward to participating with the community
- DarkWolf
30 Mar 2013 15:53 #8300
by DarkWolf
Replied by DarkWolf on topic Binding W/Rx2627H
I thought that it used the Devo protocol?
While digging around, I did find this page. www.rcproreviews.com/walkera-v120d02sv2-...p-beginner-settings/ - It also states a Devo protocol for all models.
30 Mar 2013 17:31 #8305
Replied by rbe2012 on topic Binding W/Rx2627H
I think DarkWolf is right - the "H" at the end classifies the receiver as Devo-protocol-receiver. Also the "V-D".
- HeliIntervention
30 Mar 2013 23:56 #8317
by HeliIntervention
Great link thanks! My reciever is a WK 2801Rx. I have been flying it with my 2801 Pro Tx. I think it has something to do with the fixed ID.
Replied by HeliIntervention on topic Binding W/Rx2627H
DarkWolf wrote: I thought that it used the Devo protocol?
- HeliIntervention
31 Mar 2013 23:50 #8349
by HeliIntervention
Does anyone have any idea why I can not bind to my GCP Rx2627H???
- HeliIntervention
01 Apr 2013 00:07 - 01 Apr 2013 00:07 #8350
by HeliIntervention
Never mind I figured it out. In 2801 mode a fixed ID has a default setting of 123456. Deleting the default fixed ID of 123456 resolves this issue. Which leaves the fixed ID set to (None) Maybe this should default to none since binding to a new model should have no ID until one is specified in the model!
Last edit: 01 Apr 2013 00:07 by HeliIntervention.
02 Apr 2013 08:53 #8422
Done, so use "HeliIntervention" next time when you log in...
Replied by FDR on topic Binding W/Rx2627H
HeliIntervention wrote: Also can someone help me fix my screenname it should read as HeliIntervention. I would be so grateful to have this fixed. I had a
Time to create page: 0.174 seconds
- Binding W/Rx2627H
