Gyro Programming for miniCP on Devo 8S
- Gerhard_H
30 Mar 2013 21:01 #8310
by Gerhard_H
Gyro Programming for miniCP on Devo 8S was created by Gerhard_H
Hi !
I'm sorry, this seems to be no problem for all of you but I am unable to get the gyro working for my miniCP, my very first attempt to program a heli by myself. Though I could make the heli run properly I don't know how to make the settings for the gyo, which should be activated by the MIX-switch.
I had found here a message which says (marc from 13. Oct 2012):
Walkera minicp: beginner settings
This beginner configuration is based on the 8k-template in the deviation user manual and on the beginner configuration by TomZ at rcgroups.
- FMode 0: Throttle max. 80, pitch curve -11 to 78, indoors or no wind.
- FMode 1: Throttle max. 86, pitch curve -35 to 87, outdoors
- (FMode 3: Throttle V-curve 81-13-81, linear pitch curve -100 to 100)
- Gyro sensitivity on Mix Switch: 63-57-47.
- Throttle hold: see mixer on ch 3.
Convenient icon must be in directory /modelico.
OK, what "user manual" ? Haven't found any template there (Deviation Firmware User Manual Version 1.0, downloaded from here)
Gyro sensitivity on Mix Switch . . . Yes, what else ! But how can I do this ?
The manual doesn't mention the word "gyro" not one time.
Sorry, simply downloading a proper ini-file isn't really a help for me.
How can I obtain access to the mix-switch ? Where is the gyro-issue to find in the radio menu ?
I am totally frustrated and desperate.
I hope someone can give some advice.
tia
Gerhard
tia
Gerhard
- Gerhard_H
30 Mar 2013 21:49 #8313
by Gerhard_H
Replied by Gerhard_H on topic Gyro Programming for miniCP on Devo 8S
Hi !
Got it.
Just had to find out the proper channel for the gyro (checked the miniCP manual) and to go to the mixer menu.
My excitement had been for nothing . . .
Gerhard
Got it.
Gerhard
- RandMental
30 Mar 2013 22:02 #8315
by RandMental
Replied by RandMental on topic Gyro Programming for miniCP on Devo 8S
You mentioned a version 1 manual?. Try the latest, still draft, but it might help - it is under the topic of Documentation
- sbstnp
31 Mar 2013 05:06 - 31 Mar 2013 05:07 #8323
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic Gyro Programming for miniCP on Devo 8S
Gerhard_H,
Before you attempt any programming you must know the channel order. Here what you'll find for Devo:
1. ELE
2. AIL
3. THR
4. RUD
5. GEAR
6. PITCH (AUX1)
7. GYRO (AUX2)
8. AUX3
Keep in mind this order isn't fixed for all (all-in-one) receivers/models and sometimes you have to check the specific documentation.
Also, different protocols use different channel order, like TAERG (throttle, aileron, elevator, rudder, gear), TEARG. Channels above 6 are AUX channels and their purpose is usually vendor/model dependent.
I feel we should have a sticky on this subject, it would clear a lot of things for beginners. I'll write something up this weekend and post it.
1. ELE
2. AIL
3. THR
4. RUD
5. GEAR
6. PITCH (AUX1)
7. GYRO (AUX2)
8. AUX3
Devo 10 + 4in1
Last edit: 31 Mar 2013 05:07 by sbstnp.
- Gerhard_H
31 Mar 2013 11:07 #8336
by Gerhard_H
@sbstnp
Yes, that's exactly one of the biggest problems, channel order mostly is unknown and not so easy to figure out.
@RandMental
Sorry, but I couldn't find any manual under "topic of Documentation"
Regards
Gerhard
@RandMental
Regards
Gerhard
01 Apr 2013 04:26 - 01 Apr 2013 04:27 #8353
Replied by vlad_vy on topic Gyro Programming for miniCP on Devo 8S
Last edit: 01 Apr 2013 04:27 by vlad_vy.
- Gerhard_H
01 Apr 2013 10:25 #8357
by Gerhard_H
thx, just downloaded
Time to create page: 0.388 seconds
- Gyro Programming for miniCP on Devo 8S
