Inlstalling Devo 12
05 Apr 2013 15:24 #8571 by Freezywilly
Inlstalling Devo 12 was created by Freezywilly
I must have missed a step when trying to install to my devo 12.
I open the dfuse tool but it will not recogonize my transmitter.
Yes I am using the latest release
Any suggestions?
05 Apr 2013 15:32 - 05 Apr 2013 15:33 #8572 by vlad_vy
Replied by vlad_vy on topic Inlstalling Devo 12
Do you press trainer switch before power on Devo 12?
Last edit: 05 Apr 2013 15:33 by vlad_vy.
05 Apr 2013 15:36 - 05 Apr 2013 15:38 #8573 by Freezywilly
Replied by Freezywilly on topic Inlstalling Devo 12
Yes I know about the trainer switch however made no difference.
Normal power up does show the stock program.
Using the trainer switch goes into USP mode but dfuse does not recognize it.
Heh that should be USB mode.
Last edit: 05 Apr 2013 15:38 by Freezywilly. Reason: mispelling
05 Apr 2013 15:42 - 05 Apr 2013 15:47 #8574 by vlad_vy
I had the same problem when I used long USB cable. Devo 12 use USB cable for charging and if cable is too long (or used front USB port) or USB power is too weak, dfuse does not recognize Devo 12. Try to use rear USB port on desktop PC.
What version of Windows do you use?
Last edit: 05 Apr 2013 15:47 by vlad_vy.
05 Apr 2013 15:54 #8575 by Freezywilly
I am using windows 8
Cable in rear usb port made no difference.
I will look for another cable and try again.
05 Apr 2013 16:02 #8576 by Freezywilly
I tried an external USB powered hub but no difference
05 Apr 2013 16:07 - 05 Apr 2013 16:13 #8577 by vlad_vy
Dfuse not always works well with Windows 7 and Windows 8.
If you have any other USB devices, try to remove them. Possible you have USB conflict.
Last edit: 05 Apr 2013 16:13 by vlad_vy.
05 Apr 2013 16:13 #8578 by PhracturedBlue
Replied by PhracturedBlue on topic Inlstalling Devo 12
As vlad said, you might search around for other copies of the DFuSe software. I know some folks found the 1.3 or 1.4 worked better than 1.5. One of these days I'll write my own software so we don't need to deal with this crap anymore.
05 Apr 2013 16:17 #8579 by vlad_vy
05 Apr 2013 16:25 #8580 by Freezywilly
Nope tried 1.4 and same problem.
I have windows 7 but prefer using windows 8 at this time.
I wonder if the battery charging process on the devo 12 is part of the problem?
I did not fully charge before starting the process.
05 Apr 2013 16:35 #8581 by Freezywilly
Something else is going on. I tried my devo 10 and have the same problem on the latest version.
05 Apr 2013 16:38 #8582 by Freezywilly
I tried ver 1.4 and used the devo 10 same problem.
We have a weird problem going on.
I will go back to window 7 later and try.
Stay tuned.
05 Apr 2013 17:26 #8587 by FDR
Replied by FDR on topic Inlstalling Devo 12
Have you tried the current v1.7 DfuSe?
05 Apr 2013 18:38 #8591 by Freezywilly
That is what I have. Replaced all previous versions.
They are still available but don't work now.
05 Apr 2013 19:37 #8597 by Freezywilly
Back to Spektrum
See you when you get a Linux version
05 Apr 2013 23:53 #8604 by Freezywilly
One last question. The forum says support for the devo 12 does this include the devo 12s?
Is there any real difference?
Is there a hidden gotcha here?
As I have the 12s I wonder if I have been beating a dead horse.
06 Apr 2013 04:16 #8609 by nerwin
Replied by nerwin on topic Inlstalling Devo 12
Yes, the 12s is supported.
When you put your transmitter in upgrade mode, what does it display on its lcd? When you plug it in, what appears in your device manager?
06 Apr 2013 13:20 #8630 by Freezywilly
Ok first: The device manager shows STM32 DFU with no firmware installed.
Windows can't find anything to install.
Walera does not list anything for the STM32
I will have to go back to the other download page and see if I can find anything.
06 Apr 2013 13:25 #8631 by vlad_vy
Update driver, driver located at C:\Program Files\devention Upgrade Tools\Driver
06 Apr 2013 13:32 #8633 by Freezywilly
Well I czn't get the drivers to install.
Tried running as administrator but nothing works
Time to create page: 0.211 seconds
