Inlstalling Devo 12
- Freezywilly
05 Apr 2013 15:24 #8571
by Freezywilly
Inlstalling Devo 12 was created by Freezywilly
I must have missed a step when trying to install to my devo 12.
I open the dfuse tool but it will not recogonize my transmitter.
Yes I am using the latest release
Any suggestions?
Any suggestions?
05 Apr 2013 15:32 - 05 Apr 2013 15:33 #8572
Replied by vlad_vy on topic Inlstalling Devo 12
Do you press trainer switch before power on Devo 12?
Last edit: 05 Apr 2013 15:33 by vlad_vy.
- Freezywilly
05 Apr 2013 15:36 - 05 Apr 2013 15:38 #8573
by Freezywilly
Replied by Freezywilly on topic Inlstalling Devo 12
Yes I know about the trainer switch however made no difference.
Normal power up does show the stock program.
Using the trainer switch goes into USP mode but dfuse does not recognize it.
Heh that should be USB mode.
Last edit: 05 Apr 2013 15:38 by Freezywilly. Reason: mispelling
05 Apr 2013 15:42 - 05 Apr 2013 15:47 #8574
I had the same problem when I used long USB cable. Devo 12 use USB cable for charging and if cable is too long (or used front USB port) or USB power is too weak, dfuse does not recognize Devo 12. Try to use rear USB port on desktop PC.
What version of Windows do you use?
Last edit: 05 Apr 2013 15:47 by vlad_vy.
- Freezywilly
05 Apr 2013 15:54 #8575
by Freezywilly
I am using windows 8
Cable in rear usb port made no difference.
I will look for another cable and try again.
- Freezywilly
05 Apr 2013 16:02 #8576
by Freezywilly
I tried an external USB powered hub but no difference
05 Apr 2013 16:07 - 05 Apr 2013 16:13 #8577
Dfuse not always works well with Windows 7 and Windows 8.
If you have any other USB devices, try to remove them. Possible you have USB conflict.
Last edit: 05 Apr 2013 16:13 by vlad_vy.
05 Apr 2013 16:13 #8578
Replied by PhracturedBlue on topic Inlstalling Devo 12
As vlad said, you might search around for other copies of the DFuSe software. I know some folks found the 1.3 or 1.4 worked better than 1.5. One of these days I'll write my own software so we don't need to deal with this crap anymore.
- Freezywilly
05 Apr 2013 16:25 #8580
by Freezywilly
Nope tried 1.4 and same problem.
I have windows 7 but prefer using windows 8 at this time.
I wonder if the battery charging process on the devo 12 is part of the problem?
I did not fully charge before starting the process.
- Freezywilly
05 Apr 2013 16:35 #8581
by Freezywilly
Something else is going on. I tried my devo 10 and have the same problem on the latest version.
- Freezywilly
05 Apr 2013 16:38 #8582
by Freezywilly
I tried ver 1.4 and used the devo 10 same problem.
We have a weird problem going on.
I will go back to window 7 later and try.
Stay tuned.
Stay tuned.
05 Apr 2013 17:26 #8587
Replied by FDR on topic Inlstalling Devo 12
Have you tried the current v1.7 DfuSe?
- Freezywilly
05 Apr 2013 18:38 #8591
by Freezywilly
That is what I have. Replaced all previous versions.
They are still available but don't work now.
- Freezywilly
05 Apr 2013 19:37 #8597
by Freezywilly
Back to Spektrum
See you when you get a Linux version
- Freezywilly
05 Apr 2013 23:53 #8604
by Freezywilly
One last question. The forum says support for the devo 12 does this include the devo 12s?
Is there any real difference?
Is there a hidden gotcha here?
As I have the 12s I wonder if I have been beating a dead horse.
- nerwin
06 Apr 2013 04:16 #8609
by nerwin
Replied by nerwin on topic Inlstalling Devo 12
Yes, the 12s is supported.
When you put your transmitter in upgrade mode, what does it display on its lcd? When you plug it in, what appears in your device manager?
- Freezywilly
06 Apr 2013 13:20 #8630
by Freezywilly
Ok first: The device manager shows STM32 DFU with no firmware installed.
Windows can't find anything to install.
Walera does not list anything for the STM32
I will have to go back to the other download page and see if I can find anything.
06 Apr 2013 13:25 #8631
Update driver, driver located at C:\Program Files\devention Upgrade Tools\Driver
- Freezywilly
06 Apr 2013 13:32 #8633
by Freezywilly
Well I czn't get the drivers to install.
Tried running as administrator but nothing works
Time to create page: 1.193 seconds
- Inlstalling Devo 12
