New Gaui X5 with BeastX and AR6210 +Deviation 3.0
13 Apr 2013 06:58 #8912 by togy
On a Devo 8s.
Is the setup a safe combination? I've been flying a 450 pro with a walkera receiver with great success previously I. v2.1.
Is the Deviation v3.0 stable using DSMX and the AR6210 and one dsmx satellite? Any tips? Anything I should think about or do?
Thank you very much in advance!
Best regards,
Tom
14 Apr 2013 17:41 #8929 by togy
Do any one know?
14 Apr 2013 18:36 - 14 Apr 2013 18:36 #8931 by Fishfiend
Not quite the same I know, but I'm running the devo 8s on deviation 3.0 with an AR7200bx on a 450pro with no problems at all, just need to remember to allocate the tail gyro to the gear channel..
Last edit: 14 Apr 2013 18:36 by Fishfiend. Reason: miised info
14 Apr 2013 20:31 #8935 by togy
Fishfiend wrote: Not quite the same I know, but I'm running the devo 8s on deviation 3.0 with an AR7200bx on a 450pro with no problems at all, just need to remember to allocate the tail gyro to the gear channel..
Great! Approximately, how many flights have you had on the setup?
15 Apr 2013 04:48 - 15 Apr 2013 04:49 #8942 by vlad_vy
togy wrote: On a Devo 8s.
Best regards,
Tom
I think AR6210 has full failsafe (Preset Failsafe) on throttle channel only. All other channels hold last position (SmartSafe). If it's not a problem for you, all other have to be OK.
Last edit: 15 Apr 2013 04:49 by vlad_vy.
15 Apr 2013 05:43 #8944 by Fishfiend
I only set it up 2 weeks ago..But I've had about 15 flights with no problems, I've even flown(hovered) my mates Goblin 700 by binding to it the ar7200bx on it. Full control just make sure when you bind you use 8ch not 7ch,. Smart safe is set when first binding with the throttle channel all the way down.. It works great.
15 Apr 2013 05:47 #8945 by togy
Best regards,
Tom
Ok, thank you for the information. That's actually what I prefer! My concern is if I will have a steady radio link with out glitches. A year ago running walkera firmware I had numerous glitches that caused some crashes. So my main question is: is Deviation 3.0 DSMX stable and reliable?
15 Apr 2013 05:55 #8946 by vlad_vy
I haven't any problems with v3.0 and DSMX.
15 Apr 2013 06:01 #8947 by togy
vlad_vy wrote: I haven't any problems with v3.0 and DSMX.
Ok then I'll be running it on my new X5 that comes with the post today:-)
Time to create page: 0.196 seconds
