- Emu crashes when switching to standard mode
- holywest
17 Apr 2013 21:45 - 17 Apr 2013 21:47 #9012
by holywest
Emu crashes when switching to standard mode was created by holywest
I tried it with emu v 3.0 and with the nightly build from april 8th.
I loaded the emu and the filesystem and did no changes.
When I switch to standard mode, the programm quits unassigned. There are two ways to crash the emu:
- Loading the template "heli_std.ini"
- changing mixer GUI in Model setup
I´ve not tried to do this with my radio. Because of this falut, I prefer to use V 2.1.1 at my radio.
The errors.txt ist empty.
Thanks for any support!
Last edit: 17 Apr 2013 21:47 by holywest.
18 Apr 2013 04:18 #9018
Replied by FDR on topic Emu crashes when switching to standard mode
Strange, because my emulator doesn't crash if I switch to the standard GUI...
- holywest
18 Apr 2013 05:45 #9020
by holywest
Replied by holywest on topic Emu crashes when switching to standard mode
Hi FDR,
Tanks for your response. Max be it's Not a general problem. But I' like to solve it.
The emu runs on a system with Win XP latest SP. The 2.1,1. emu ist installed too and it runs w/o any problems.
So I can see 3 enviroments that can be reasonable:
Win XP
Parallel installation of 2.1.1
Maybe the 3.0 uses the wrong dll?
Any ideas?
Win XP
Any ideas?
18 Apr 2013 06:05 - 18 Apr 2013 07:05 #9021
Replied by vlad_vy on topic Emu crashes when switching to standard mode
I get the same result, deviation-emu_devo8-v3.0.0.exe crashed with template heli_std.ini and changing mixer GUI to Standard mode.
But, with source code compiled version, emu_devo8.exe works fine.
Last edit: 18 Apr 2013 07:05 by vlad_vy.
- RandMental
18 Apr 2013 06:54 #9022
by RandMental
Replied by RandMental on topic Emu crashes when switching to standard mode
I have confirmed I don't get any crashes on the emu_devo8, build from the latest code in PB's repo, when loading heli_std.ini or changing mixer GUI to Standard mode or back.
18 Apr 2013 07:25 - 18 Apr 2013 07:31 #9023
Forgot to mention, that my emulator (emu_devo8.exe) is a built one from the latest source...
EDIT: the released devo8 emulator indeed crashes...
Last edit: 18 Apr 2013 07:31 by FDR.
- holywest
18 Apr 2013 08:15 #9024
by holywest
How can I get this latest release?
18 Apr 2013 08:44 #9025
It's the same as latest night build. But emu from night build crashes.
Compiled emu_devo8.exe with libraries.
Attachment emu_devo8.ZIP not found
- RandMental
18 Apr 2013 08:50 - 18 Apr 2013 08:57 #9026
by RandMental
This is not good, is there a way we can update the formal release and nightly builds to our local builds without PB? He mentioned he won't have much time for a few weeks.
Last edit: 18 Apr 2013 08:57 by RandMental.
18 Apr 2013 09:03 - 18 Apr 2013 09:05 #9028
We can place compiled emulators v3.0 (with libraries) at 'Builds' section. All needed libraries can be found in 'emu_devo8.ZIP'.
Last edit: 18 Apr 2013 09:05 by vlad_vy.
- holywest
18 Apr 2013 09:16 #9029
by holywest
This emu does not crash. Thanks a lot
But what´s the difference to the latest nightly build?
vlad_vy wrote: Compiled emu_devo8.exe with libraries.
19 Apr 2013 17:00 #9057
Replied by PhracturedBlue on topic Emu crashes when switching to standard mode
sorry everyone. I hope I'll be more available starting very soon now.
I will check my build system and see if I can identify the cause. The builds are fully automated, and are different than my development environment. I don't see the crash in my development environment. There is no change between the posted exe and the official one (other than one crashes and the other does not)
- domcars0
19 Apr 2013 17:38 #9063
by domcars0
Replied by domcars0 on topic Emu crashes when switching to standard mode
May be this is related to
deviationtx.com/forum/7-development/1239...d-in-emu-devo10#6901
I've found a turnaround but ...
Time to create page: 1.482 seconds
