Emu crashes when switching to standard mode
17 Apr 2013 21:45 - 17 Apr 2013 21:47 #9012 by holywest
I tried it with emu v 3.0 and with the nightly build from april 8th.
I loaded the emu and the filesystem and did no changes.
When I switch to standard mode, the programm quits unassigned. There are two ways to crash the emu:
- Loading the template "heli_std.ini"
- changing mixer GUI in Model setup
I´ve not tried to do this with my radio. Because of this falut, I prefer to use V 2.1.1 at my radio.
The errors.txt ist empty.
Thanks for any support!
Last edit: 17 Apr 2013 21:47 by holywest.
18 Apr 2013 04:18 #9018 by FDR
Strange, because my emulator doesn't crash if I switch to the standard GUI...
18 Apr 2013 05:45 #9020 by holywest
Replied by holywest on topic Emu crashes when switching to standard mode
Hi FDR,
Tanks for your response. Max be it's Not a general problem. But I' like to solve it.
The emu runs on a system with Win XP latest SP. The 2.1,1. emu ist installed too and it runs w/o any problems.
So I can see 3 enviroments that can be reasonable:
Win XP
Parallel installation of 2.1.1
Maybe the 3.0 uses the wrong dll?
Any ideas?
18 Apr 2013 06:05 - 18 Apr 2013 07:05 #9021 by vlad_vy
Replied by vlad_vy on topic Emu crashes when switching to standard mode
I get the same result, deviation-emu_devo8-v3.0.0.exe crashed with template heli_std.ini and changing mixer GUI to Standard mode.
But, with source code compiled version, emu_devo8.exe works fine.
Last edit: 18 Apr 2013 07:05 by vlad_vy.
18 Apr 2013 06:54 #9022 by RandMental
Replied by RandMental on topic Emu crashes when switching to standard mode
I have confirmed I don't get any crashes on the emu_devo8, build from the latest code in PB's repo, when loading heli_std.ini or changing mixer GUI to Standard mode or back.
18 Apr 2013 07:25 - 18 Apr 2013 07:31 #9023 by FDR
Forgot to mention, that my emulator (emu_devo8.exe) is a built one from the latest source...
EDIT: the released devo8 emulator indeed crashes...
Last edit: 18 Apr 2013 07:31 by FDR.
18 Apr 2013 08:15 #9024 by holywest
How can I get this latest release?
18 Apr 2013 08:44 #9025 by vlad_vy
It's the same as latest night build. But emu from night build crashes.
Compiled emu_devo8.exe with libraries.
Attachment emu_devo8.ZIP not found
18 Apr 2013 08:50 - 18 Apr 2013 08:57 #9026 by RandMental
This is not good, is there a way we can update the formal release and nightly builds to our local builds without PB? He mentioned he won't have much time for a few weeks.
Last edit: 18 Apr 2013 08:57 by RandMental.
18 Apr 2013 09:03 - 18 Apr 2013 09:05 #9028 by vlad_vy
We can place compiled emulators v3.0 (with libraries) at 'Builds' section. All needed libraries can be found in 'emu_devo8.ZIP'.
Last edit: 18 Apr 2013 09:05 by vlad_vy.
18 Apr 2013 09:16 #9029 by holywest
vlad_vy wrote: Compiled emu_devo8.exe with libraries.
This emu does not crash. Thanks a lot B) B)
But what´s the difference to the latest nightly build?
19 Apr 2013 17:00 #9057 by PhracturedBlue
Replied by PhracturedBlue on topic Emu crashes when switching to standard mode
sorry everyone. I hope I'll be more available starting very soon now.
I will check my build system and see if I can identify the cause. The builds are fully automated, and are different than my development environment. I don't see the crash in my development environment. There is no change between the posted exe and the official one (other than one crashes and the other does not)
19 Apr 2013 17:38 #9063 by domcars0
Replied by domcars0 on topic Emu crashes when switching to standard mode
May be this is related to
deviationtx.com/forum/7-development/1239...d-in-emu-devo10#6901
I've found a turnaround but ...
Time to create page: 0.891 seconds
