binding RX-2801 is not WK-2801 compatible
25 Apr 2013 13:31 #9197 by Kiebitz
I use a DEVO 10 with deviation 3.0. Thank you for this great firmware.
I only have a little problem with my RX-2801 receivers.
ID binding of WK-2801 does not bind at devioation. I have to set the ID new . This binds then not with the WK-2801.
Thanks for help
  • rbe2012
  • rbe2012's Avatar
25 Apr 2013 14:12 - 25 Apr 2013 14:12 #9198 by rbe2012
Replied by rbe2012 on topic binding RX-2801 is not WK-2801 compatible
There is a bug report for this in bitbucket: fixed-id-is-not-the-same
You can get some background info there.
As far as I know there is no solution yet.
Last edit: 25 Apr 2013 14:12 by rbe2012.
25 Apr 2013 14:24 #9200 by Kiebitz
Replied by Kiebitz on topic binding RX-2801 is not WK-2801 compatible
Thank you
Time to create page: 0.298 seconds
