Model transfers to V3 Model folder
- clearprop88
26 Apr 2013 22:10 - 26 Apr 2013 23:18 #9251
by clearprop88
Model transfers to V3 Model folder was created by clearprop88
I'm confused by this statement in the V3 Manual. I'm just trying to get V3 setup right.
"copy all directories EXCEPT for the ‘models’ directory and the
tx.ini file to the transmitter. Optionally, copy the ‘models’ directory to the transmitter except for the currently configured model files."
Does this mean that I should copy the new V3 Model folder from the FS zip file into my Devo 8S, and then carefully copy in my Model .ini files into the new Model folder, or does it mean that I have to re-configure all my existing Model files?
I guess what I'm really asking is;
Can I Use my old Model folder, and copy it into the new V3 File system Model folder.
Another question;
Is there a difference in the unused Model files used in V2.0 compared to V3.0 or are they the same?
Another question;
Last edit: 26 Apr 2013 23:18 by clearprop88. Reason: add
27 Apr 2013 03:52 #9257
Replied by vlad_vy on topic Model transfers to V3 Model folder
They are different. You need copy the new V3 model folder from the FS zip file into your Tx, then copy your model .ini files into the new model folder.
- clearprop88
27 Apr 2013 04:19 #9258
by clearprop88
Replied by clearprop88 on topic Model transfers to V3 Model folder
Thanks very much vlad.
That clears it up for me.
Also, are the templates different in V3 compared to earlier releases?
27 Apr 2013 04:32 - 27 Apr 2013 04:35 #9259
I think there are changes in Heli/Standard template. There are changes at media folder.
The best way to update filesystem - delete all, copy new, restore your model ini files and tx.ini.
Last edit: 27 Apr 2013 04:35 by vlad_vy.
- clearprop88
27 Apr 2013 05:17 #9262
by clearprop88
OK. Will do.
Thanks again.
Thanks again.
- blackmoon
27 Apr 2013 20:41 #9282
by blackmoon
Replied by blackmoon on topic Model transfers to V3 Model folder
Do not restore Tx.ini, use the one with the FS for your Devo build, recalibrate and reconfigure.
I don't understand why, it should work with older ones but I had some quirks when I used an old tx.ini.
- clearprop88
28 Apr 2013 01:04 #9286
by clearprop88
I think that's good advice.
Just load everything in new, and then make changes from there, adding in old models, templates, skins, etc.
I will also review my model config files just to be sure that all the switches do what I expect them to do.
28 Apr 2013 07:52 #9299
Replied by FDR on topic Model transfers to V3 Model folder
You will probably have to reconfigure the toggle icons...
- clearprop88
28 Apr 2013 16:22 #9319
by clearprop88
I'm not quite sure what that means.
Does it mean that I have to reconfigure all my switches in my model configuration files?
28 Apr 2013 16:54 #9321
Usually all switches works fine. But icons on the main screen associated with switches my be wrong.
- clearprop88
28 Apr 2013 17:49 #9323
by clearprop88
OK. I'll watch for that.
I like the Advanced mode, so all my config. files were developed using that mode, but I would like to experiment using the icons in basic mode.
- NotFastEnuf
29 Apr 2013 18:00 #9339
by NotFastEnuf
Replied by NotFastEnuf on topic Model transfers to V3 Model folder
I used the tx.ini that came with v3 and recalibrated - no problem. However, I deleted the models folder that came with the v3 filesystem and copied my previous model folder in. Other than the toggle icons needing to be reconfigured - I have not had any problems. Did I do something wrong here? I also removed and recopied my icons folder. Please advise if I have caused a problem that will show itself later by erasing the v3 models folder and copying in my previous model folder.
29 Apr 2013 19:21 #9341
Replied by rbe2012 on topic Model transfers to V3 Model folder
You should be fine.
The icons are independent, they were just shown on the screen.
The model config files are compatible, only the toggle icon references changed.
The only thing you should do when copying your models to the new folder: do not overwrite the default.ini and unused model files because they can contain changes to the old defaults.
- NotFastEnuf
30 Apr 2013 10:09 #9383
by NotFastEnuf
Well I did overwrite everything cause I deleted the v3 folder. I will try to set up a new model tonight and see if its causing any unexpected behavior using the old version blank models.
Time to create page: 0.407 seconds
- Model transfers to V3 Model folder
