- Can keys EXT/ENT/LRUD be used to start/stop timer?
- richardclli
28 Apr 2013 06:25 #9292
by richardclli
Can keys EXT/ENT/LRUD be used to start/stop timer? was created by richardclli
It seems not supported, please tell me if I am wrong. However using these keys should be better so that switches can be used for other functions.
- RandMental
28 Apr 2013 06:35 #9294
by RandMental
Replied by RandMental on topic Can keys EXT/ENT/LRUD be used to start/stop timer?
No, these key are dedicated as command keys in the software.
On the hardware side there is no difference compared to the other keys and in theory it can work. The difficulty would be to decide on consistent rules for such dual function keys - when a press is meant as command and when as function key.
- domcars0
28 Apr 2013 09:02 - 28 Apr 2013 09:06 #9301
by domcars0
Replied by domcars0 on topic Can keys EXT/ENT/LRUD be used to start/stop timer?
I think that you can always use the R(ight) button to reset the timers (but not the permanent).
If you configure a timer with a Start cmd set to None, it will start/stop with the L(eft) button.
Last edit: 28 Apr 2013 09:06 by domcars0.
- richardclli
30 Apr 2013 12:41 #9390
by richardclli
Replied by richardclli on topic Can keys EXT/ENT/LRUD be used to start/stop timer?
Seems your suggestions is not working in my Devo 8S
- ave1
10 May 2013 21:12 #9815
by ave1
Replied by ave1 on topic Can keys EXT/ENT/LRUD be used to start/stop timer?
May I ask? Somehow I was successful at making a timer start with the throttle, once the throttle is raise, collective is given. But how do you make a button to reset the timer?
I hope you might help me, please?
- domcars0
10 May 2013 21:32 - 10 May 2013 21:34 #9817
by domcars0
On Devo6/8/12 short click on a timer start/stop it, long click reset it.
On Devo7/10 R(ight) button start/stop timers with switch set to None, L(eft) button reset all (not permanents) timers.
Last edit: 10 May 2013 21:34 by domcars0.
- richardclli
11 May 2013 00:30 #9821
by richardclli
I have tried Devo 8S with Deviation, but I cannot find any of the ENT/EXT/UP/DOWN/LEFT/RIGHT buttons have any effect to the timers.
Time to create page: 0.206 seconds
