delayed Flap system for fixed wing
- kenkenlau
05 May 2013 16:51 #9602
by kenkenlau
delayed Flap system for fixed wing was created by kenkenlau
Is it able to add delayed flap system ?
in DX8, you can set a delay from 0.1s to 16s for flap input. When you switch on the flap, it will slowly and smoothly feed in the flap within the time selected
So you will not experience a sudden deceleration when you switch on the flap.
05 May 2013 16:57 #9603
Replied by PhracturedBlue on topic delayed Flap system for fixed wing
Yes this is supported using the 'speed' config on the limits page of the advanced mixer
- kenkenlau
05 May 2013 19:17 #9605
by kenkenlau
Replied by kenkenlau on topic delayed Flap system for fixed wing
Arh.....
Sorry, I spent an hour digging thru and still cannot find it......
Would you mind teach me how to go to the setting?
05 May 2013 19:33 #9607
Replied by rbe2012 on topic delayed Flap system for fixed wing
Go on the mixer config page where the channels are listed on the left (1-ELE, 2-AIL, ...) and the chosen mixer on the right (simple, expo, complex...).
When you touch the "1-ELE" button a config page opens where you can make channel-specific configurations, with the last one you can change the speed setting.
- kenkenlau
05 May 2013 19:47 #9609
by kenkenlau
oh....got it. Thanks
I tried to find it in a vir channel and have some test
- Hexperience
06 May 2013 15:48 #9617
by Hexperience
Replied by Hexperience on topic delayed Flap system for fixed wing
Yes, speed is not available in a virtual channel, which I'm still hoping will change. If I was a better programmer I'd try it myself, but I don't want to hack at the mixer too much.
Once speed can be used on a virtual channel and is applied in such a way that it can be used as a source, we can do some neat tricks with the speed setting.
Maybe I'll have a hack at it just to see what happens in the emulator...
- domcars0
06 May 2013 17:03 - 06 May 2013 17:05 #9622
by domcars0
Replied by domcars0 on topic delayed Flap system for fixed wing
In fact I think that at this time if your flap system use the AIL/ELEV servos, it's not possible because you can only set speed for servo... Hexperience is right when he says that we need to be able to set speed by mixer.
Last edit: 06 May 2013 17:05 by domcars0.
- shadow
14 May 2013 02:06 #9967
by shadow
Replied by shadow on topic delayed Flap system for fixed wing
if there is a spare ch like aux he could use that channel as a source for the flaps and slow that chan.
Might have to try that on my own. humm.
14 May 2013 03:48 #9968
The speed is applied to the output after all mixing has taken place. so you can't use the speed-adjusted output as an input into another channel.
You'll need to wait until I redesign the mixer to enable applying speed during mixing instead of only at the end.
Time to create page: 0.309 seconds
- delayed Flap system for fixed wing
