DEVO 6 TX Power out
07 May 2013 20:16 #9682 by clearprop88
DEVO 6 TX Power out was created by clearprop88
When I select 150mw power out on my Devo 6 is it actually outputting 150mw?
Is there some attenuation in the stubby antenna.
I think what I'm really asking is the range the same as my Devo 8 on 150mw?
08 May 2013 02:33 #9686 by PhracturedBlue
Replied by PhracturedBlue on topic DEVO 6 TX Power out
go check the FCC website on the power output. I think the Devo6 is very close to the devo8 in power. Neither will likely actually achieve 150mW as this would be pushing the power-amp at about its limit and there is quite a bit of falloff up there.
08 May 2013 02:51 #9688 by clearprop88
Replied by clearprop88 on topic DEVO 6 TX Power out
Just to satisfy my curiosity I'll do a range check to compare the two tansmitters.
08 May 2013 07:35 #9701 by RandMental
Replied by RandMental on topic DEVO 6 TX Power out
I have not checked the Devo6 at the time, but here is a previous post with the links to the FCC site for the other TX's
www.deviationtx.com/forum/7-development/...-work?start=400#5313
08 May 2013 18:27 #9714 by clearprop88
Thanks for the link RM. I knew it must have been discussed before. Someone said that the range of the Devo 6s is 600 M, if it's true I think that's a pretty good range. That's a long Par 5, and farther than I can see.
Time to create page: 0.091 seconds
