replacement stock 2.4 module
- spiegel
21 May 2013 05:40 #10183
by spiegel
Replied by spiegel on topic replacement stock 2.4 module
Thank you for the answers.
I am ready to replace it. All the parts are prepared:
Antenna, cable, pin socket and module.
As the below picture, do I connect blue circles to red circles?
21 May 2013 05:53 - 21 May 2013 05:56 #10184
Replied by vlad_vy on topic replacement stock 2.4 module
No need to do it. You can fix module at place by any other means.
Last edit: 21 May 2013 05:56 by vlad_vy.
- airheli1201
31 May 2013 23:34 #10470
by airheli1201
Replied by airheli1201 on topic replacement stock 2.4 module
I just installed the devo 8s module to my 7e. Do I need to modify the tx.ini to get full power and range?
01 Jun 2013 05:16 #10474
Check that you have at tx.ini
[modules]
enable-cyrf6936=B12
has_pa-cyrf6936=1
[modules]
enable-cyrf6936=B12
has_pa-cyrf6936=1
- Neo2a
26 Mar 2014 06:21 #21839
by Neo2a
Replied by Neo2a on topic replacement stock 2.4 module
Dear Friends,
Please Help me,
Can I update my Devo 12 transmitter
to Devo 12S if I exchange the ( WK-DEVO-S-MOD )?
Walkera online support person said I can not.
Is it valid? No way to updae?
Thank you
Neo2a
Please Help me,
Thank you
Neo2a
26 Mar 2014 06:31 #21840
Replied by FDR on topic replacement stock 2.4 module
Yes you can.
The case will be different, but nevermind.
Here are the sources, which have the module:
www.ehirobo.com/transmitters-receivers/m...-upgrade-module.html
www.hobbyone.com.hk/cn/product.jsp?id=10896
- Neo2a
- moss
04 Dec 2014 19:26 #26766
by moss
Replied by moss on topic replacement stock 2.4 module
WK-DEVO-S-MOD
makes the transmitters be able to use telemetry? (i.e. has a new RX path?)
Is there an MCU on this board?
- 92zb
12 Aug 2016 09:51 #52698
by 92zb
I could not find this doc on Walkera site. Would you please be more preciese. Thanks.
Replied by 92zb on topic replacement stock 2.4 module
PhracturedBlue wrote: look at the docs for installing a module on your radio in the 'Downloads' section. You'll find a pic that labels the pins
12 Aug 2016 12:35 #52701
PB didn't refer to the Walkera site, but our own Downloads section, however since than it was moved into the Wiki:
www.deviationtx.com/wiki/rf_module_installation
Time to create page: 0.202 seconds
- replacement stock 2.4 module
