Battery voltage calibration
- kenkenlau
15 May 2013 10:33 #10015
by kenkenlau
Battery voltage calibration was created by kenkenlau
I am using 2S Lipo and the battery display is 0.8 less than actual value. Any chance to calibrate it?
Or which .c file should I look into and modify?
15 May 2013 12:26 #10020
Replied by rbe2012 on topic Battery voltage calibration
You can modify the target/[your tx model]/target_defs.h file. At the end you will see the formula and the parameters.
- junpower
21 Sep 2013 21:39 #13968
by junpower
Replied by junpower on topic Battery voltage calibration
Hi rbe, could you please advise more detail on how to calibrate the voltage display ? Like how to access to (target/[your tx model]/target_defs.h file)
thanks
thanks
- domcars0
21 Sep 2013 21:48 #13969
by domcars0
Replied by domcars0 on topic Battery voltage calibration
You will have to download the source code from the BitBucket PB repository and
setup the programming environment to build (compile) the firmware yourself after changing the parameters in the file
src/target/[your tx model]/target_defs.h
where [your tx model] is your TX model (devo10 for ex.)
- RRacer
22 Sep 2013 00:07 #13972
by RRacer
That might be true, but it's a major hurdle for most Deviation users.
On top of that, you have to go through that process after every firmware update.
My tx displays fairly accurate supply voltage, but it seems that the variation is quite large between different transmitters, even when comparing the same model.
A solution to this might be to have a calibration value in the tx.ini file for easy editing, eliminating the need of a complete developer toolchain and the steep learning curve associated with it.
Replied by RRacer on topic Battery voltage calibration
domcars0 wrote: Hi,
- domcars0
22 Sep 2013 19:51 #13991
by domcars0
You are right.
- sfersystem
12 Jun 2014 19:27 - 12 Jun 2014 19:28 #24054
by sfersystem
Replied by sfersystem on topic Battery voltage calibration
I have the same problem with à Turnigy 9xr 3s lipo. Is there something new about that ?
Thx
Thx
Last edit: 12 Jun 2014 19:28 by sfersystem.
- Gyori
13 Jun 2014 19:45 #24070
by Gyori
Replied by Gyori on topic Battery voltage calibration
Hello Everybody,
I found that maybe the RPM value also not accurate (I think, about 10%).
I've checked the RPM sensor with a signal generator and an oscilloscope,
and its output signal seemed good for me (1 edge/Hz (only even numbers are possible, so 120 1/min resolution) ).
I guess, the telemetry module can cause the difference or the TX with the Deviation 4.0.1.
Have anybody else experienced similar?
Best regards!
Best regards!
Time to create page: 0.609 seconds
- Battery voltage calibration
