Suggestion for a new telemetry function
15 May 2013 18:42 #10035 by brerax
I have just installed Deviation v3.0.0 on my 12s. Right now I’m just familiarizing myself with the menus and the new functions.
When I came to the Telemetry monitor page I had an idea for a new function. How about two new buttons on this page? The first button would tare the altitude value so that the value is the height above ground and not the height above sea level.
The second button would be a memory function that saves the highest value on altitude and on speed. That way you could record the highest values during a flight without having to look at the screen during the flight.
  • Raimili
  • Raimili's Avatar
  • DEVO 12S "Slope-Gliders" wellcome
16 May 2013 20:26 #10057 by Raimili
Replied by Raimili on topic Suggestion for a new telemetry function
... brilliant Idea ... you have my support!
greetz
Raimili
...(hoping that anyone creates a simple Mixer GUI (Sailplane) for noopes like me)
13 Jun 2013 03:51 #10889 by adabman
Replied by adabman on topic Suggestion for a new telemetry function
Excellent idea. I really could use the altitude tare function.
I am just getting started with Deviation at this point, but intend on getting a build environment setup, and the altitude "tare" function is what i was going to try and hack in first .. Also some timezone support, so the WK-GPS reported time would show proper.
Your second idea sounds great also.
Deviation :) 1 TX to rule them all...
  • Raimili
  • Raimili's Avatar
13 Jun 2013 05:23 #10898 by Raimili
My Walkera Telemetry is with GPS Data very exact.
Much more better than the GPS on Iphone4
Ok, Altitude not realy...
But, if a have a wish to come truth; and when anyone would make a better telemetry page:
Is there any chance to hold the last position on screen?
Because, when the plane falls down and the GPS send no more data, i could see nothing on the screen.
If i could see the last send position on the page i will find my plane much more better!
And there is no need to see aktually the Speed when i fly.
But MAX & MIN Scores after the flight are very good informations.
That are my wishes to a good telemetry page.
Grettings from Germany
Raimund
13 Jun 2013 05:27 #10899 by vlad_vy
Replied by vlad_vy on topic Suggestion for a new telemetry function
I believe telemetry screen retain last values on red background in case lost of telemetry signal.
  • Raimili
  • Raimili's Avatar
13 Jun 2013 05:32 #10900 by Raimili
Uuhh,
i dont have seen it, sorry.
But what do you think about the other suggestions?
Are there feasible?
greetz
Raimund
13 Jun 2013 05:33 #10901 by magic_marty
Replied by magic_marty on topic Suggestion for a new telemetry function
Really great idea! Would be cool to know how high up you went and what is the top speed you traveled while flying.Hopefully wont be to hard to implement this into the firmware..:)
  • Raimili
  • Raimili's Avatar
13 Jun 2013 06:09 #10906 by Raimili
also the low speed is very interesting:
Dreaming Modus on:
"You fly the plane so slow plane till it stalls.
Now, after the fight you see the slowest speed, for Example: 26 km/h
Then you will set a stall-warning maybee at 30 km/h.
So the RX can warn you before it stalls.
In the next step maybee the Deviation can do that."
Dreaming Modus off.
Oh,oh my brain is wide.....
Raimund
13 Jun 2013 06:14 - 13 Jun 2013 06:23 #10907 by adabman
vlad_vy is correct. I can confirm I can see the last gps position in red after removing power to the model.
All good ideas!
Screens Look like this:
Last edit: 13 Jun 2013 06:23 by adabman.
  • rbe2012
  • rbe2012's Avatar
13 Jun 2013 07:06 #10912 by rbe2012
Replied by rbe2012 on topic Suggestion for a new telemetry function
Raimili wrote: Dreaming Modus on:
Where should we dream if not here??
I have not so much experience with planes / none with gliders but I believe that stalling is an effect which is depending on the wind speed too, not the absolute speed in relation to the ground. Will this be valuable?
  • Raimili
  • Raimili's Avatar
13 Jun 2013 07:19 #10913 by Raimili
Hi rbe,
yes you are right.
You must note the windspeed.
But at landing it´s alway a little game.
You will fly slow as you can...
esp. Hotliners
Whith a little wind you can ignore the stall-warning a little bit longer.
...the dream go on...
13 Jun 2013 07:46 #10916 by FDR
Replied by FDR on topic Suggestion for a new telemetry function
I see an other problem:
the program cannot tell if you are actually flying, so when you are landing, and the model stops, it will still trying to remember that speed as the lowest...
  • Raimili
  • Raimili's Avatar
13 Jun 2013 07:50 #10917 by Raimili
Oh, yes that it´s a problem, right.
and i don´t have a solution.
maybe anyone else?
13 Jun 2013 16:15 #10930 by adabman
Use a switch to "arm"/"enable" the new function after takeoff..
Flip the switch back when ready to land?
13 Jun 2013 16:22 #10932 by adabman
As seen in the pics I posted, there is a need to calibrate the 4 temp sensors also..
Time to create page: 0.600 seconds
