Simplified Mixer for Sailplane?
- Raimili
- DEVO 12S "Slope-Gliders" wellcome
17 May 2013 01:48 #10065
by Raimili
...(hoping that anyone creates a simple Mixer GUI (Sailplane) for noopes like me)
Simplified Mixer for Sailplane? was created by Raimili
Hello together,
Is a simple mixer for sailplane in working progress?
I´ve tried nor for over a week to understand the Mixer GUI.
I´ve resigned now.
I will work aktualy with the org. Firmware and FDR´s Library on my DEVO 12.
It´s for me the best way to fly my models.
But, deviantfx is so an amazing projekt - I will not give up.
But, my hope will not die.
I fly sailplanes up to 4 mtr, and i have absolute no doubt about the tx.
The Widescreen GUI that ive tried from Wene001 is a good solution.
But the mixer´s - i don´t understand.
Are there toughts to create a siple mixer
(similary to the Helicopter section)?
Good ideas (foundation) I found here:
www.deviationtx.com/forum/3-feedback-que...simplified-mixer-gui
or another vehicle, here:
www.deviationtx.com/forum/3-feedback-que...-work-in-the-devo-12
Please be patient for my silly english
in hope
Raimili
I´ve resigned now.
in hope
Raimili
- BitOne
17 May 2013 08:45 #10067
by BitOne
Replied by BitOne on topic Simplified Mixer for Sailplane?
Hi Raimili,
I can understand the mixer could be quite intimidated, but it's also really powerful as it gives you so much freedom on what you can accomplish.
The learning curve could be steep, but it's very logical and once you got the main concepts, the other parts come to light easily.
So if could explain us what you want to do exactly, we could help you come to a solution.
- sbstnp
17 May 2013 09:19 #10068
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic Simplified Mixer for Sailplane?
Hi, I'm sure the Advanced mixer cannot be that complicated.
I'll make you a deal:
1. You describe in detail what you need
2. I create a step-by-step tutorial which could then be made available as a sticky for everyone to use.
What do you say?
We can start with the first step: general configuration of your ship, meaning mapping channels to servos and sticks.
What do you say?
Devo 10 + 4in1
- Raimili
17 May 2013 10:02 - 17 May 2013 10:08 #10069
by Raimili
Replied by Raimili on topic Simplified Mixer for Sailplane?
Thank´s together! - you are all so helpfull.
Maybe we can make a little instruction for "Mixer Dummies".
Ok, i post the config of my (for me) complicated sailplane:
RX-Basics:
ELEV: Elevator
AIl: AileronR
THRO: ESC-Motor
RUDD: Rudder
GEAR: Gear
AUX1: AileronL
AUX2: SpoilerR
AUX3: SpoilerL
My Wishes:
I fly in Mode1 (AIL/THRO right Side)
Differential of the 2 AIL´s 40% down
AIL to Rudder 100%
3 FMode Modes, switching with the FMode Switch
Start (Switch down),
Soaring (Switch middle,
Landing (Switch high),
Description of the Modes:
Start: AilL&AilR 10% down
Soaring: AilL&AilR 0%
Landing: AILR&AILL 30% down, SPOILERR&SPOILERL 95% up
ELEV 5% up
GEAR goes down
and all this Mod´s slides on and off (1/1) when the Trottle goes from -10- +90%.
For me it´s very,very tricky, maybe I understand the powerfull Mixer by a template - how it works.
Greetings from a rainy day in Germany.
Raimili
RX-Basics:
ELEV: Elevator
AIl: AileronR
THRO: ESC-Motor
RUDD: Rudder
GEAR: Gear
AUX1: AileronL
AUX2: SpoilerR
AUX3: SpoilerL
My Wishes:
AIL to Rudder 100%
ELEV 5% up
GEAR goes down
Raimili
Last edit: 17 May 2013 10:08 by Raimili.
- sbstnp
17 May 2013 10:14 - 17 May 2013 10:16 #10070
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
I don't undestand this part, can you go into detail a bit more?
I understand throttle controls camber, right?
PS: this isn't very complicated, I'll work on it tonight after my kid goes to sleep and get back to you
Raimili wrote: and all this Mod´s slides on and off (1/1) when the Trottle goes from -10- +90%.
Devo 10 + 4in1
Last edit: 17 May 2013 10:16 by sbstnp.
- Raimili
17 May 2013 10:42 - 17 May 2013 10:51 #10071
by Raimili
Hi sbstnp,
in Landing mode the situation is as follow:
I will landing - FMode Switch in Landing Mode:
The Throttle is in 0% Position = no Motor will run.
AIl, ELEV, Spoilers goes to the devined Landing Positions.
But when the landing preparedness missmatch, - i must restart.
With the Trottle Stick i will give Motor-Power, but also now all other Positions must return sliding to normal "Soaring" Position.
You are so helpfull...
when I get your Template, i will try to understand the Mixer.
You have all the time you need - tomorrow the weather ssems to be god (i will slope) - but the next (rainy) days a have full time to try to understand..
Greetings
Raimili
Greetings
Raimili
Last edit: 17 May 2013 10:51 by Raimili.
- sbstnp
21 May 2013 04:09 #10181
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
I'm still working on this, haven't had much free time to complete it but it's almost done
Devo 10 + 4in1
- Raimili
21 May 2013 04:53 #10182
by Raimili
Hi sbstnp,
no problem.... take all the time you need...
raimili
raimili
- sbstnp
26 May 2013 16:11 #10322
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
Still a few days on the road. Working on the document, I'm half way.
Bonus pics from earlier today: Airbus 318 wing with and without flaps. Missed the shot with the airbrakes.
Devo 10 + 4in1
- Raimili
27 May 2013 18:38 #10347
by Raimili
Iám also on the road last 2 days,
thanks for the flight pictures..
Grettz from Germany
Raimund
Grettz from Germany
Raimund
Time to create page: 0.772 seconds
- Simplified Mixer for Sailplane?
