button matrix and Jog Dial
- kenkenlau
25 May 2013 18:32 #10301
by kenkenlau
button matrix and Jog Dial was created by kenkenlau
I am looking into the tx_buttons.c and quite confusing about the buttonmap[] declare. In Eclipse it say BUT_LEFT unresolved......dont know where BUT_XXXX are declared.
And if I wish to add jog dial support, am I looking at the right place?
25 May 2013 18:59 #10302
Replied by rbe2012 on topic button matrix and Jog Dial
Look into the capabilities.h - there are the buttons defined. The construct used there was not easy to understand for me, but it is quite brilliant: the capabilities.h is included in other files where a "#define"-directive tells what to do with the information: the buttons are defined in inputs.c:
const char *INPUT_ButtonName(u8 button)
if (! button) {
return _tr("None");
#define BUTTONDEF(x) case BUT_##x : return BUTNAME_##x;
switch(button) {
#include "capabilities.h"
#undef BUTTONDEF
return "";
}- rbe2012
25 May 2013 19:01 #10303
Oh, for a jog dial don't you need two input lines? Aren't they phase-shifted to recognize the direction? Or do you mean something else?
- kenkenlau
25 May 2013 19:30 #10304
by kenkenlau
Replied by kenkenlau on topic button matrix and Jog Dial
yes, phase shifted for direction. plus a push in button.
So i think need to modify some code to detect the phase. In assembly, it is very simple with a -ve edge IRQ
but in C++ I am still learning how to implement it.
Worst case is adding a tiny MCU to feed in the button matrix, but I think its a stupid idea.
If the code is done, I may build a 3D printing button that can replace the ENT button. so that the ENT button can roll and press.
EXINT1_ISR: //Update_JogAB via IRQ
push PSW
mov C, port_JogB
mov bit_JogA, C
cpl C
mov bit_JogB, C
pop PSW
retibut in C++ I am still learning how to implement it.
- kenkenlau
25 May 2013 19:33 #10305
by kenkenlau
using this one.
rbe2012 wrote: Oh, for a jog dial don't you need two input lines? Aren't they phase-shifted to recognize the direction? Or do you mean something else?
using this one.
Time to create page: 0.104 seconds
- button matrix and Jog Dial
