- WK2801 protocol with RX2612V 4F200 ...problem
- CmdrKeen
01 Jun 2013 00:35 #10472
by CmdrKeen
WK2801 protocol with RX2612V 4F200 ...problem was created by CmdrKeen
i am running the latest nightly build on my devo12s.
Binding with the RX2612V from my 4F200 is not correct some times.
I tried with 8 and 7 channels. It is worse with 8.
(channel 7 is the gyro, witch does not work with WK2601 and 7 channels)
The Binding seems to be succesful but it appears as if the channels are somehow broken sometimes: servos are not responding or worse : throttle is high.
the first binding procedure after connecting the battery is ok or at least not harmfull bad. but if i re-init the TX without powering down the model, it might cause the motor to spin up. (which was not good ... maybe i was lucky not to get hit)
are there any known issues?
04 Jun 2013 21:23 #10567
Replied by PhracturedBlue on topic WK2801 protocol with RX2612V 4F200 ...problem
I haven't seen this issue before. Unfortunately each Rx has its own quirks, so I'm not sure how easily I can replicate this with my setup. I'll at least try to bind with the Wk27801 Rx I have an see if I see anything similar.
- CmdrKeen
06 Jun 2013 08:57 #10635
by CmdrKeen
Replied by CmdrKeen on topic WK2801 protocol with RX2612V 4F200 ...problem
Thanks for looking into that.
I also have tried this on a 4#3b with the WK2401 protocoll.
It behaved a bit different but i could reproduce the problem too.
sometimes only the tailrotor spins like crazy and sometime the main motor.
It seems to me, that during the 12sec bind process the model has problems with wrong inputs and after that i dont have controll over all channels.
so for the time beeing i would recommend to never re-init the TX with an already bound WK-RX.
I still have to test what happens if the connection is lost due to low signal strength.
06 Jun 2013 09:48 #10638
Replied by rbe2012 on topic WK2801 protocol with RX2612V 4F200 ...problem
As far as I remember (haven't tried for a while) I had only two cases:
complete rebind (rarely) with every channel working and no unexpected moves or no binding at all (had to restart the rx).
I will try again if an actual version shows such issues with my helis/rx.
Time to create page: 0.800 seconds
