Devo 12s upgradeing and Model memory?
06 Jun 2013 05:38 #10628 by Kdean
when i flash my devo 12s will the models remain saved as is? Or, do i have to save the models somewhere before i flash and reload after? How is this done?
06 Jun 2013 06:02 - 06 Jun 2013 06:04 #10630 by vlad_vy
Replied by vlad_vy on topic Devo 12s upgradeing and Model memory?
If you upgrade original Devo 12s firmware, you will lost all models and Tx config. You can save models one by one at Dfuse 'Config' tab. Select model 'Number' and perform 'Upload' file.
If you upgrade Deviation firmware and filesystem, you need before upgrade save all used model (modelXX.ini) files from Tx filesystem to PC.
Last edit: 06 Jun 2013 06:04 by vlad_vy.
Time to create page: 0.472 seconds
