Problem with timer and auto bailout for CC escs
09 Jun 2013 23:05 - 09 Jun 2013 23:12 #10743 by flint723
Castle escs allow you to set up an auto bailout, where you set your TH value higher than -100 (-70 on my 450). Then if you use TH, it shut off the motor, but if you flip it off again, it spools up much faster than the original soft start. So that part works great.
The only problem is that when I have TH engaged, the timer (set to ch3) is counting because the Throttle value is above -95. So what I am wondering is if it would be possible for me to change the timer stop/start value to a different value?
Thanks in advance.
Last edit: 09 Jun 2013 23:12 by flint723.
10 Jun 2013 00:05 #10745 by PhracturedBlue
Replied by PhracturedBlue on topic Problem with timer and auto bailout for CC escs
you cannot set the timer trigger point, but you could setup a virtual channel which was throttle - 30, and use that as the input to the timer.
10 Jun 2013 04:30 - 10 Jun 2013 04:31 #10751 by Kdean
I just set my count down timer to start when i click throttle hold off (HOLD0). Im using a 12s so i set the trainner switch to re-set the timer. Very convenient when you have to land and make adjustments to the heli in the middle of o flight.
I have an ice 50 on a trex 450pro, and i had to set my hold at -84% to use the auto bail out feature.
Last edit: 10 Jun 2013 04:31 by Kdean.
14 Jun 2013 14:29 #10956 by flint723
Thanks guys.
Time to create page: 0.128 seconds
