How to trigger AUX1 in Stock..
- thekid
10 Jun 2013 10:23 #10754
by thekid
How to trigger AUX1 in Stock.. was created by thekid
hey folks!
at the moment i am back at stock firmware on my 8s.
anyone knows how i can control aux1 output on my RX ? got an RX701
regards.
alex
regards.
alex
10 Jun 2013 10:42 - 10 Jun 2013 10:43 #10755
Replied by vlad_vy on topic How to trigger AUX1 in Stock..
At heli mode it's impossible, AUX1 channel = Pitch channel
At airplane mode AUX1 channel = Flap channel, at 'Device Output' menu you can select for Flap - FMODE SW, MIX SW, Left trim or Right trim. At 'Flap System' menu you can setup 3 positions for flaps.
At any case you can try to setup zero curve/value (0% for all range) for Pitch or Flap channel and use program mix from other channel (AUX2 or AUX3) to Pitch or Flap channel.
Last edit: 10 Jun 2013 10:43 by vlad_vy.
- thekid
10 Jun 2013 13:20 #10759
by thekid
Replied by thekid on topic How to trigger AUX1 in Stock..
Ok,
thanks for the request.
Got my TX in Airplane mode, connected a servo to aux 1, FMOD SW is assigned to FLAPS (i see the movements of the FLAPS on the servo Indication page)
but the servo doesnt move ...
i canNOT select the Flap System menu, its gray and not selectable.
any ideas? thanx
rgds alex
any ideas? thanx
rgds alex
10 Jun 2013 13:27 #10760
Set at Device Output -> Flap = Active
- thekid
10 Jun 2013 13:29 #10761
by thekid
i just figured out whats wrong...
tried another RX and everything worked fine.
i think may the AUX1 output of the RX is broken.
great work, thank you very much!
Time to create page: 0.074 seconds
- How to trigger AUX1 in Stock..
