Question regarding Deviation on 7e and model setup
11 Jun 2013 00:30 #10777 by Usjak
I installed Deviation 3.0.0 on Devo 7e and FlySky module from heli v911. Hardware appears to be working as I am able to bind to Hubsan X4, but only if I go to Models setup and load file: Hubsan X4. Auto bind when Tx is switched on does not work for some reason. I used model file from here:
www.deviationtx.com/forum/model-configs/1227-hubsan-x4-config
Used file is HbsanX4.ini, copied to models directory and renamed to model1.ini. The protocol directory is also copied.
Also, the graphs in Mixer setups are not drawn.
What I am doing wrong here?
13 Jun 2013 12:08 #10923 by Usjak
Fixed with nightly build 5c895b. Thanks!
Time to create page: 0.128 seconds
