Swash plate levelling
- cropduster
15 Jun 2013 11:49 #10986
by cropduster
Swash plate levelling was created by cropduster
Hi all,
I have a T-REX 450 with RX2702V-D and previously bound to DEVO stock firmware and library, with swash plate perfectly levelled after binding in default position.
Now I switched to deviation firmware (v3.0.0 with RBE's Devo12 wide screen version cc895a) and I set swash type to 3servo 120 with a swash mix of 40/40/70, same as I had with stock firmware.
Now 2 problems:
1. swash plate is no longer level. It is slightly tilted to one side. Can I adjust via subtrim or other functions or do I need to change it mechanically by adjusting the push rod lenghts?
2. It seems like I have better results with choosing swash type 1servo with the rx2702V-D than with 3servo 120, which should be correct option. with 3servo 120 the cyclic movements are mixed, so I use ELE and also AIL serveos move.
Thanks for your help,
Michael
Now 2 problems:
Michael
- RandMental
15 Jun 2013 21:06 #10995
by RandMental
Replied by RandMental on topic Swash plate levelling
Make sure you have calibrated the sticks after loading Deviation.
If it is still not level, adjust the push rods and use subtrim to do the fine tuning.
This receiver needs a 3 servo/120deg setting on the Tx side.
Time to create page: 0.591 seconds
- Swash plate levelling
