Help with Devo 10 mix
- gordonzo
16 Jun 2013 19:26 #11017
by gordonzo
Different fly for different guy.
Help with Devo 10 mix was created by gordonzo
Could someone please point me in the right direction on complex (I assume) mix?
On my Devo 10 and FBL 70:
I want to add a fwd elev mix to left rudder to smooth out the left turns. Any help would be appreciated.
regards . . . g
regards . . . g
- gordonzo
19 Jun 2013 04:59 #11109
by gordonzo
Replied by gordonzo on topic Help with Devo 10 mix
Spent a bunch more time digging and now I can answer my own question:
To add a fwd elev mix to left rudder, I did a complex mix add to the Elev with a >0 curve and small positive offset. I had to reduce the scale to 40% to get a small enough change.
To add rev elev mix to right rudder I did a complex mix add to the Elev with a <0 curve and small negative offset. I also had to reduce the scale to 50%.
Disclaimer: This is for my FBL 70 which has nicked blades and a 4x glued swashplate, and may need to be re-adjusted when parts are renewed. At first I tried to add a Elev mix to the Rud which seemed more logical, but it was very squirrely. So I added Rud mix to the Elev. I consider this to be a functioning work in progress.
regards . . . g
regards . . . g
19 Jun 2013 05:07 #11110
Replied by FDR on topic Help with Devo 10 mix
If you need a mix for both the positive and negative half, you would be better with one 3 point curve...
Time to create page: 0.410 seconds
- Help with Devo 10 mix
