How to assign a switch to a channel
19 Jun 2013 01:54 - 19 Jun 2013 02:35 #11103 by Pattaya01
How to assign a switch to a channel was created by Pattaya01
I haven't figured out yet how to assign a 3 way switch to a channel. What I need is this:
FMOD switch to channel 7, -100%, 0%, +100%.
Is there a simple way to do this or does it have to be done through the mixers? If through the mixers, how to do that?
Edit: I know how to do through the mixer...
Last edit: 19 Jun 2013 02:35 by Pattaya01.
  • rbe2012
  • rbe2012's Avatar
19 Jun 2013 10:47 #11112 by rbe2012
Replied by rbe2012 on topic How to assign a switch to a channel
There is no other way but the mixer...
06 Aug 2013 03:08 #12781 by dwhacks
Replied by dwhacks on topic How to assign a switch to a channel
I dont even get how to do this with the mixer! ha.
06 Aug 2013 05:07 #12782 by FDR
Replied by FDR on topic How to assign a switch to a channel
You can use the Expo&DR template for that:
- leave the source at none;
- select fixed as the function;
- choose the FMODE1 and FMODE2 for the switches;
- set -100, 0 and +100 for the scale values.
06 Aug 2013 12:31 #12789 by dwhacks
Thank you!
06 Sep 2016 10:36 #53542 by Infamous2117
Replied by Infamous2117 on topic How to assign a switch to a channel
I just used this to setup up flight modes on my CC3D.
You are a lifesaver my friend!
Time to create page: 0.213 seconds
