Ardupilot flight mode setting
- Pattaya01
25 Jun 2013 10:00 #11333
by Pattaya01
Ardupilot flight mode setting was created by Pattaya01
The Ardupilot has 1 input channel to select the flight modes. To be able to select all six modes, you have to configure your RC transmitter to do this.
That is usually accomplished by mixing a two position switch and a three position switch on the transmitter. You have to set your switch(es) to (ideally) produce PWM pulse widths of 1165, 1425, and 1815 microseconds for 3 modes or 1165, 1295, 1425, 1555, 1685, and 1815 milliseconds for 6 modes.
Does anyone has an idea how to do this for 6 modes on the Deviation software? (I know how to do for 3 modes)
Information about the settings can be found here:
code.google.com/p/ardupilot-mega/wiki/APM2RCSetup
25 Jun 2013 10:18 - 25 Jun 2013 10:34 #11336
Replied by vlad_vy on topic Ardupilot flight mode setting
You can use complex mixer with 4 pages. First 3 pages ('replace' mux) with 3-position switch (SWX_0, SWX_1, SWX_2) and 3 fixed values (1165, 1425, and 1685), last (4th) page ('add' mux) with 2-position switch (SWY_1) that can add small fixed positive value (add 130) for each replace mux (1295, 1555, and 1815).
Last edit: 25 Jun 2013 10:34 by vlad_vy.
- Pattaya01
25 Jun 2013 10:39 #11337
by Pattaya01
Replied by Pattaya01 on topic Ardupilot flight mode setting
I think I got it. But I think it has to be 5 pages. If use 4 pages, it doesn't go down enough. The 5th page will add minus value to minus value, so reach to minus 100%.
Thanks, I now understand the system.
25 Jun 2013 10:50 #11338
You can use 'Offset' at 4th page to add additional throw.
- tito74
26 Jun 2013 18:25 #11428
by tito74
Replied by tito74 on topic Ardupilot flight mode setting
Can you show me how you programmed that?
Thank you.
Thank you.
- Pattaya01
- tito74
27 Jun 2013 10:24 #11445
by tito74
Fantastic. Thank you a lot.
- magic_marty
19 Jul 2013 16:35 #12339
by magic_marty
Replied by magic_marty on topic Ardupilot flight mode setting
its to bad there is no way to add a 6 position rotary switch to the Devo8 ...on rcg they were adding them to other tx's but not sure it could be done to the devo8...
- Pattaya01
27 Jul 2013 03:55 - 27 Jul 2013 04:00 #12544
by Pattaya01
I have refined the way the switches are allocated and came up with this solution (applicable for the Devo12S):
The FMOD switch defines 3 stages: MAN-STAB-AUTO
The RUDD D/R switch defines 3 stages: CIRC-FMOD-RETL
The RUDD D/R switch is kind of a "panic" button and either lets the FMOD switch define the mode or overrides whatever mode has been selected to either circle or return to launch.
The programming is very simple:
Choose whatever channel you have dedicated to your fly mode and choose "Complex", 6 mixers
Page 1: Switch - FMODE0, Curve - Fixed, Scale - 70, MUX - Replace
Page 2: Switch - FMODE1, Curve - Fixed, Scale - 45, MUX - Replace
Page 3: Switch - FMODE2, Curve - Fixed, Scale - 10, MUX - Replace
Page 4: Switch - RUD DR1, Curve - Fixed, Scale - 0, MUX - add
Page 5: Switch - RUD DR2, Curve - Fixed, Scale - -73 (Minus 73), MUX - Replace
Page 6: Switch - RUD DR0, Curve - Fixed, Scale - -47 (MInus 47), MUX - Replace
This will give you 5 flight modes where the RUDD D/R switch overrides the FMOD switch in position 0 and 2. Position 1 leaves the modes to the FMOD switch.
On the mission planner, define as follows:
Flight mode 1, RTL
Flight mode 2, CIRCLE
Flight mode 3, STABILIZE (Will not be selected)
Flight mode 4, Auto
Flight mode 5, STABILIZE
Flight mode 6, Manual (cannot be changed)
So flight mode 3 will not be selected by any position of any switch and can be set to anything. Fight mode 6 is the default manual flight mode and cannot be changed.
This works fine on the Devo12S. Sure it can be implemented on others as well, I'm just don't know how as I only have the 12S.
Hope this helps anyone flying with the APM 2.5.
Flight mode 1, RTL
Flight mode 4, Auto
Last edit: 27 Jul 2013 04:00 by Pattaya01.
- Josephking87
15 Mar 2016 05:23 #44584
by Josephking87
Replied by Josephking87 on topic Ardupilot flight mode setting
Do you know of any YouTube videos on this setup? I'm new to the deviation firmware and have no idea how to do any of this lol.
Time to create page: 0.201 seconds
- Ardupilot flight mode setting
