Feature request - Output Snapshot
26 Jun 2013 07:58 #11381 by RRacer
Feature request - Output Snapshot was created by RRacer
Hello all,
I think it would be useful if I could set a switch to save current channel output to a file.
This way I could fly my heli/plane in a way that I think is correct for emergency situations, press the assigned switch (preferably one of the trims as they are momentary) and have all values recorded to a file.
I could then use whatever values from that file in the models failsafe settings.
I did a brief search of the forum for similar requests but didn't find any.
28 Jun 2013 21:48 #11532 by RRacer
Replied by RRacer on topic Feature request - Output Snapshot
Anyone?
I feel that setting failsafe values is an important thing, it's just difficult to know _what values_ to put in there, and I think this feature would help.
I know this feature exist in some form on other transmitters, and I kind of think that it's not a very difficult thing to add.
But then again, I'm not a programmer.
29 Jun 2013 03:20 #11537 by PhracturedBlue
Replied by PhracturedBlue on topic Feature request - Output Snapshot
Not exactly what you are looking for, but the next release will contain data-logging capability. You could set it up to capture all state when a specific trigger happens.
The specific abilityto copy the current state to the trims/sub-trims has been asked for before, but it isn't particularly easy with the general-purpose mixer implementation in Deviation.
02 Jul 2013 13:07 #11736 by RRacer
PhracturedBlue wrote: Not exactly what you are looking for, but the next release will contain data-logging capability. You could set it up to capture all state when a specific trigger happens.
That sounds good!
The functionality I'm after is not likely to be used very frequently, so I don't mind a little tinkering when it's needed.
Time to create page: 0.701 seconds
