Devo6 -> Pitch curve -> Invalid ini
27 Jun 2013 21:10 - 27 Jun 2013 21:11 #11470 by wluijk
Devo6 -> Pitch curve -> Invalid ini was created by wluijk
Hello. I am new here. What do i need to do? I have file access to the TX and v3.0.0 is loaded.
Last edit: 27 Jun 2013 21:11 by wluijk.
  • rbe2012
  • rbe2012's Avatar
28 Jun 2013 05:08 #11489 by rbe2012
Replied by rbe2012 on topic Devo6 -> Pitch curve -> Invalid ini
If you have a tx and deviation is running you should be fine.
Ok, to be serious: I can not recognize which kind of problem you have. Please tell us more about the config you want to build, the config you have and what does not work as expected.
28 Jun 2013 05:19 - 28 Jun 2013 05:20 #11490 by vlad_vy
Replied by vlad_vy on topic Devo6 -> Pitch curve -> Invalid ini
Possible firmware v3.0 is loaded, but filesystem not rewrited/renewed.
Last edit: 28 Jun 2013 05:20 by vlad_vy.
Time to create page: 0.038 seconds
