TRIM_L & TRIM_R on Devo 10?
30 Jun 2013 20:34 #11648 by mwm
TRIM_L & TRIM_R on Devo 10? was created by mwm
Now that I finally got the Devo 10, I started fooling with the extra trim switches to see what I could do with them.
First thing - just attach them to AUX4 and AUX5. Set them up identical to the setups for four stick trims, with Trim- to TRIM_L- and Trim+ to TRIM_L+ for AUX4.
Seems like they're backwards: pushing the left trim up towards the '+' symbol lowers the output of AUX4, and pushing it down towards the '-' raises it. It's easy to fix, but...
Am I just confused?
Maybe this is a bug?
Could my Tx be wired backwards (both of them do that, so it doesn't seem likely)?
30 Jun 2013 21:42 - 30 Jun 2013 21:51 #11651 by domcars0
Replied by domcars0 on topic TRIM_L & TRIM_R on Devo 10?
Why did you attach AUX to TRIM ? On the Devo10 there are already buttons for that (they are just in the middle-top of the TX)...
Last edit: 30 Jun 2013 21:51 by domcars0.
01 Jul 2013 00:23 #11652 by PhracturedBlue
Replied by PhracturedBlue on topic TRIM_L & TRIM_R on Devo 10?
mwm is just saying that the trim 5 and 6 seem to be hooked up backwards. you need to associate them with some channel in order to test them. I don't have my devo10 in front of me to check it. If someone can confirm, I'll fix it, otherwise you'll need to wait till I dig it out.
Please file a ticket on bitbucket so I don't forget about this.
01 Jul 2013 22:19 #11692 by mwm
Replied by mwm on topic TRIM_L & TRIM_R on Devo 10?
As PBR said, they have to be attached to something. They weren't attached to those channels by default, so I picked them as the obvious ones.
I created the issue: bitbucket.org/PhracturedBlue/deviation/i...em-to-be-upside-down
01 Jul 2013 22:40 #11693 by domcars0
As yes excuse me,I understand my mistake, sorry.
And yes there is the bug, trim+ (up) decrease channel output value while trim-(down) increase it.
02 Jul 2013 02:52 #11699 by PhracturedBlue
Are both trim 5 and trim6 backwards, or just trim 5? It isn't clear from the 1st post.
02 Jul 2013 07:25 - 02 Jul 2013 07:34 #11718 by vlad_vy
Replied by vlad_vy on topic TRIM_L & TRIM_R on Devo 10?
Sorry for offtopic, but what to do the negative trim step? I changed negative values but don't understand what they do.
Last edit: 02 Jul 2013 07:34 by vlad_vy.
02 Jul 2013 07:44 #11719 by Kdean
Replied by Kdean on topic TRIM_L & TRIM_R on Devo 10?
While we are talking about trims, i want to share an idea/suggestion. I post this in another thread about making trims act as switches, which i think is a good idea and would make programing mulitple mixes, such as flaps, not so limited by 2 or 3 switch positions. I also would like to use trims instead of bargraphs in the display. They should be able to display other channels and not be limited to just showing trim position.
I also noticed, with the devo12, that some of the dials inputs are reversed when displayed in the input monitor. Eg. Aux 2 when pushing dial up the bargraph moves down, but when pushing the dial up for aux3 on the other side, the bargraph moves up. Is this normal?
02 Jul 2013 10:15 #11724 by sbstnp
Replied by sbstnp on topic TRIM_L & TRIM_R on Devo 10?
Kdean wrote: I also noticed, with the devo12, that some of the dials inputs are reversed when displayed in the input monitor. Eg. Aux 2 when pushing dial up the bargraph moves down, but when pushing the dial up for aux3 on the other side, the bargraph moves up. Is this normal?
Aren't they mirrored physically? Probably this behavior is technically correct, but intuitively it should both move up when pushed up.
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
02 Jul 2013 13:39 #11740 by Scream
Replied by Scream on topic TRIM_L & TRIM_R on Devo 10?
Hiya!
The trims are "reversed" for all 6 groups... I've been playing around with using the h/v trims for other features and noticed it a while ago...
Basically, you just "reverse" them on the trim page when you set them up :)
As far as toggels as switches go, I've been begging for that function since xmas! I think it might be cool if you needed to hold the trim button for 2 seconds so you don't accidentally enable one!
Cheers!
Cheers!
-=S=-
  • rbe2012
  • rbe2012's Avatar
02 Jul 2013 16:22 #11762 by rbe2012
Replied by rbe2012 on topic TRIM_L & TRIM_R on Devo 10?
I have never seen this but you made me curious.
I take a fresh one and load the 6Ch Helicopter template. I do not change anything else. Going to the channel monitor page I see the bars rising whether I use move the stick or the trim in the same direction (up/left). I can not see any mixup so far.
If I assign TRIML / TRIMR to channels I see the channel moving correct with TRIMR, but wrong with TRIML. Obviously TRIML moves wrong.
BTW: It is a little bit confusing that on the trim page the -trim comes before the +trim, but on the detail page the sequence is changed.
02 Jul 2013 17:10 - 02 Jul 2013 17:11 #11764 by vlad_vy
It seems that PB reversed both trims TRIML and TRIMR:
bitbucket.org/PhracturedBlue/deviation/c...92b45f7f0d23d1f60bd7
Can you check this???
Last edit: 02 Jul 2013 17:11 by vlad_vy.
  • rbe2012
  • rbe2012's Avatar
02 Jul 2013 17:32 #11767 by rbe2012
Yes, looks as if you are right. I am not sure what the problem with Devo10 was; I have made my tests with Devo12 and there is the TRIML wrong.
The position PB changed is where the button connectors go - I would have expected to change the method which reads the inputs rather than messing up the buttons...
02 Jul 2013 18:01 - 02 Jul 2013 18:08 #11768 by vlad_vy
Devo 12??? I don't see any problem with TRIML and TRIMR. With Devo 12 and Devo8.
Last edit: 02 Jul 2013 18:08 by vlad_vy.
02 Jul 2013 19:53 #11770 by PhracturedBlue
yes, this is why I assumed the problem was with the trim mapping. I need to spend some time on the devo10 and test it for myself. i just haven't yet had time. On the devo8/12 you have the button tester to verify that the buttons map as expected.
  • rbe2012
  • rbe2012's Avatar
02 Jul 2013 20:19 #11772 by rbe2012
My fault; please accept my apology. I had only little time and did not see that I have mixed it up by myself...
I am sorry for that.
02 Jul 2013 20:51 - 02 Jul 2013 20:52 #11774 by domcars0
Ok it's good now - commit fab661c - (both TRIM_L & TRIM_R was backwards).
Thanks PB
Last edit: 02 Jul 2013 20:52 by domcars0.
02 Jul 2013 22:12 #11785 by mwm
It looks like this already got answered, but just in case, both the left and right trim buttons were reversed for me.
Time to create page: 0.877 seconds
