Devo 8 battery
10 Oct 2013 07:51 #14415 by EduardS
Replied by EduardS on topic Devo 8 battery
Parkkert wrote: I am running a 3 s lipo in devo-10. Is this bad? It's run with it for many hours like 25 at least.
You might better use a 3S LiFePo4 battery. In this topic you can find good tips on this.
  • rbe2012
  • rbe2012's Avatar
10 Oct 2013 11:25 #14428 by rbe2012
Replied by rbe2012 on topic Devo 8 battery
Be careful: Devo8 has normally 4 AA-cells = 6V. The 6.6V (7.6V if full loaded) from 2s LiFe might be in acceptable range, but more than 10V will produce much heat for nothing.
Other TX have other batteries (Devo12: 1S LiPo, Devo10: 12V?)
10 Oct 2013 12:02 #14432 by RandMental
Replied by RandMental on topic Devo 8 battery
More than 8V on a Dev08s will not only generate more heat, it will most probably blow the 3.3V LDO regulator in the Devo8s which has a MAXIMUM input rating of 8V, according to the manufacturers specification sheet.
10 Oct 2013 12:37 - 10 Oct 2013 12:39 #14437 by EduardS
I don't think I have anyone seen giving the advice to go beyond 2S on the Devo 8S (only advice against going beyond, or even use, 2S) ... the 3S is for the Devo 10 ...
Last edit: 10 Oct 2013 12:39 by EduardS.
10 Oct 2013 12:45 - 10 Oct 2013 12:47 #14439 by RandMental
EduardS wrote: I don't think I have anyone seen giving the advice to go beyond 2S on the Devo 8S (only advice against going beyond 2S) ... the 3S is for the Devo 10 ...
The problem I see is that a 2S, fully charged Lipo sits at 8.4V, I would rather advise on using a 6.6V 2s LiFe. (and RBE mentioned 10V in his response in a Devo8 topic header)
But then I am back to the old question why at all - with 4x 2500mA NImH you have almost double the capacity in the same space and the easy of charging via the DSC connector without removing the battery. An added benefit is I can charge while I practice on the Simulator.
Last edit: 10 Oct 2013 12:47 by RandMental.
10 Oct 2013 13:04 - 10 Oct 2013 13:04 #14443 by EduardS
RandMental wrote: The problem I see is that a 2S, fully charged Lipo sits at 8.4V, I would rather advise on using a 6.6V 2s LiFe.
Yes, agree. That is why I advised and use LiFePo4.
The little bit extra brightness on the 8S could be an argument pro and the charge/discharge properties of LiFePo4 are "better" than that of NiMH.
Last edit: 10 Oct 2013 13:04 by EduardS.
10 Oct 2013 13:40 #14446 by RandMental
EduardS wrote: The little bit extra brightness on the 8S could be an argument pro and the charge/discharge properties of LiFePo4 are "better" than that of NiMH.
All good arguments depending on how you define "better" and for whom.
I probably look at the screen 0.1% of the time I use the TX, and even less when I am outside flying - then you look at the heli or plane and wait for the buzzer to indicate it is time to land - "brighter" for me personally is thus irrelevant.
01 Aug 2014 15:39 #24949 by Birdman
Replied by Birdman on topic Devo 8 battery
This could be a waste of time and money as my Devo 8 looks like its headed for the tip.
Anyway, i need to connect a tx module which has a min voltage of 6v. So i need to run a 2s lipo. With diode voltage comes down to below 7.5v.
Will this be ok?
I found a 2100mAH rx pack lipo. If you unscrew and remove batt holder its fits just nice.
hobbyking.com.au/hobbyking/store/__22547...k_AU_Warehouse_.html
Bm
30 Mar 2015 14:23 #30465 by Fredyp
Replied by Fredyp on topic Devo 8 battery
Hi!
Sorry for m'y english....
If the devo8s reduce power to 3.3v and i put 4x 1.2v there are less heat then 4x1.5v (with same mah) so more time whitout recharge. It's true?
Thank you!
30 Mar 2015 15:25 #30466 by PhracturedBlue
Replied by PhracturedBlue on topic Devo 8 battery
not necessarily. the 4x1.5 batteries will consume energy faster for no Tx gain (and waste it all as heat, just like you said), but you can wait for your batteries to get to a lower voltage before charging them. It really comes down to the capacity (mAH) and checmistry of the battery more than anything else.
30 Mar 2015 23:32 #30505 by Fredyp
Ok.
Thank you!
27 Feb 2017 00:14 #59662 by DSantapaola
Replied by DSantapaola on topic Devo 8 battery
Can sb tell me the correct name of the plug of the battery holder?
Thanks in advance!
27 Feb 2017 14:42 - 28 Feb 2017 17:44 #59682 by saidem
Replied by saidem on topic Devo 8 battery
It is a 2 pins 3mm JR connector.
Last edit: 28 Feb 2017 17:44 by saidem.
28 Feb 2017 12:54 - 02 Mar 2017 15:57 #59707 by DSantapaola
saidem wrote: it is a 2 pins 3mm JR connector.
Thank you very much.
Puhh...does sb know where I can buy this connector in Germany? Banggood and Hobbyking EU would be also ok, or some ebay seller. It's also used as battery plug in JR and Spektrum transmitters, but i can not find it anywhere.
Last edit: 02 Mar 2017 15:57 by DSantapaola.
06 Mar 2017 20:20 - 07 Mar 2017 16:18 #59926 by saidem
www.rc-connectors.com/index.php?main_pag...h=99&products_id=285
It seems to me that this connector is hard to find. I have seen here, but the shipping costs are very expensive and I do not know this website.
Try this:
fr.aliexpress.com/wholesale?initiative_i...s&needQuery=n&page=3
or do send a mail to wlakera parts, hobbygaga, hobbyone, ehirobo...
Otherwise it will be necessary to replace the connector by a JST connector like Devo 7E. I think you should find the picture in the forum.
Try this:
store.batteriesamerica.com/2-pinflatwhitetxconnforjrpropo.aspx
www.ebay.com.au/itm/2-JR-SPEKTRUM-TRANSM...81895147980#shpCntId
Perhaps contact a spektrum resaler in your country!
Last edit: 07 Mar 2017 16:18 by saidem.
07 Mar 2017 04:00 #59937 by DSantapaola
Uuurgs...
Thank you very much for your effort. I will try your links.
07 Mar 2017 16:18 #59967 by saidem
See above!
07 Mar 2017 17:09 #59972 by DSantapaola
saidem wrote: See above!
I asked the part service of Horizon, whether i can make an order for the part. This was last week, but I didn't get an answer. Only today they said my order is in process. I will wait and see.
Using the heading of your ebay link I found a chinese seller. Thanks! So thats an option. Otherwise, the shipping cost are insane..
07 Mar 2017 19:15 #59977 by saidem
Before placing an order, make sure that it will be the right connector, because they look very similar.;)
08 Mar 2017 00:49 #59988 by DSantapaola
saidem wrote: Before placing an order, make sure that it will be the right connector, because they look very similar.;)
I'm not sure, whether i understand you or not. Are you referring to the chinese seller i mentioned? If Horizon doensn't sell me the connector I want to buy this one:
www.ebay.de/itm/JR-Spektrum-Transmitter-...9:g:51IAAOxyCSRSEj41
Seems to me the rigth connector, or not?
Time to create page: 0.396 seconds
