How to bind LOSI Micro-Rally 2.4Ghz-BL
10 Jul 2013 20:45 #12169 by bmwbiker
How to bind LOSI Micro-Rally 2.4Ghz-BL was created by bmwbiker
I'm from Germany and my english is "a bit under the weather".
I'm flying some Walkera-Heils with very easy binding to my Devo8s.
Also I can bind verry easy some E-Flight-Helis and one Horizon-Micro-Plane.
But my new LOSI-Micro-Rally won't bind to Devo ?
The RC in the car is DSM2 , 2.4Ghz but the Devo don't bind in any configs.
I've tested DSM2 with 2/3/4/5/6/7/8/9 Channels
and also DSMX with 2/3/4/5/6/7/8/9 Channels
Thanks in advance
bmwbiker
10 Jul 2013 23:01 - 12 Jul 2013 09:55 #12171 by kille
Replied by kille on topic How to bind LOSI Micro-Rally 2.4Ghz-BL
my english is also very "basic". So it is more easily for me to answer in german ;-).
Ich hab da auch ein bissl rumgetan. Bei mir hat es nicht immer so geklappt:
Bind-plug in den empfänger
Sender an
Bind prozedur im sender einleiten
Warten bis der empfänger dauernd leuchtet
Sender aus
empfänger aus
bind-plug raus
Sender an
Empfänger an
Manchmal musste ich das aber öfter machen...
Was fährst für eine?
Grüße,
Kille
I try my best to translate my german into english.
I have also tried to bind a Orange DSM2 receiver.
My procedure was:
Bind-plug into the RX
TX on
Bind procedure start in the TX
Wait to have a solid light in the RX
TX off
RX off
remove bind-plug
TX on
RX on
Sometimes I have to repeat these steps.
Regards,
Kille
Last edit: 12 Jul 2013 09:55 by kille. Reason: add translation
  • rbe2012
  • rbe2012's Avatar
11 Jul 2013 06:38 #12175 by rbe2012
Replied by rbe2012 on topic How to bind LOSI Micro-Rally 2.4Ghz-BL
As far as I remember do the aerial and the ground receivers use a different protocol. I have no clue how great this difference will be.
If anyone gets this running this would be great. Kille, did you connect to a ground receiver?
11 Jul 2013 07:34 #12176 by kille
No, I think it was a "normal" rx.
11 Jul 2013 09:06 - 14 Jul 2013 19:37 #12183 by bmwbiker
Replied by bmwbiker on topic How to bind LOSI Micro-Rally 2.4Ghz-BL
@ Kille:
Ich hab gerade den 1:24 Micro-Rally erstanden - mit 2s-LIPO echt Krass schnell!
Wo ist der Bind-Plug? ich habe immer die Taste gedrückt und wenn die LED blinkt - die Devo binden wollen....
Translation:
@ Kille:
I just bought the 1:24 Micro Rally - with 2s LIPO the car is really fast!
Where is the bind plug? I have always pressed the bind-button and when the LED flashes - I want to bind the Devo ....
Last edit: 14 Jul 2013 19:37 by bmwbiker.
11 Jul 2013 11:43 - 12 Jul 2013 10:04 #12185 by kille
Kann dir leider nicht sagen ob das geht. Google mal. Anscheinend wie rbe2012 schon gesagt hat, gibt es da Unterschiede zwischen DSM ground und halt nicht ground.
Den Bind-Plug steckt man normalerweise in den Empfänger um die Bind-Prozedur am Empfänger einzuleiten. Der müsste dabei gewesen sein.
Translation:
I have no idea if it work. Please use Google. There are, rbe2012 wrote this already, different DSM the ground version and non ground version.
Normaly you have to plug the bind-plug into the rx to enable the bind-procedure. The bind-plug is normaly included.
Last edit: 12 Jul 2013 10:04 by kille.
11 Jul 2013 14:46 - 14 Jul 2013 19:39 #12186 by bmwbiker
Laut Manual gibt es bei dem nur einen BIND-BUTTON !
In dem Fall geht's halt nicht.
Dann doch mit 2 Sendern hantieren...
Danke für die Hilfe.
Gruß,
bmwbiker
According to the manual, there where only a BIND BUTTON!
So i have to handle with 2 RC's
Thanks for the help.
Regards,
bmwbiker
Last edit: 14 Jul 2013 19:39 by bmwbiker.
  • rbe2012
  • rbe2012's Avatar
12 Jul 2013 07:18 #12204 by rbe2012
Hey guys,
in earlier threads we have already discussed if we want to have sections of the forum in other languages than English. The result was a clear "no".
I personally think it is at least impolite not to try to translate what you have to say to English so all users can read your discussion. Writing longer parts with substantial content excludes many people from participating and helping.
And you can be sure: a lot of people here are no native English speaker so they all have the same difficulties with the English language. But even a poor translation reaches much more people than a discussion in another language.
So I propose that you try to write English. If you want to talk about something what is not of general interest you also have PM as method where you are free to choose the language.
Auch von mir ein Gruß
rbe2012
12 Jul 2013 08:11 #12205 by BitOne
Replied by BitOne on topic How to bind LOSI Micro-Rally 2.4Ghz-BL
I totally agree with rbe2012.
12 Jul 2013 10:07 #12208 by kille
I also totally agree with rbe2012 and BitOne. I have not think about this. I'm really sorry.
I have added the translation. I'm also sorry about the poor quality of my translation.
Regards,
kille
14 Jul 2013 19:42 #12244 by bmwbiker
I also agree.
Sorry for the wrong language. I've translated my posts so you can follow our short discussion.
Regards,
bmwbiker
17 Jul 2013 12:48 #12288 by kille
Do you have tested the binding again?
How do you try this?
23 Jul 2013 09:33 #12446 by bmwbiker
Sorry for my late reply.
I bind the Losi like it is shown in the manual.
I press the bind-Button and switch the car on. Then ich power my RC on - but the binding-light in the car don't stop flashing.
I test every channel-Setting with DSM2/DSMX but no binding.
In my opinion there is an other Protocol used by losi.
I gave up and i think the Losi-Controller is ok for driving this little car.
Regards,
bmwbiker
23 Jul 2013 10:18 #12447 by kille
The timing is very important.
After switching on the RC-Car by pressing the bind button, you have to switch on the tx. Than you have to press the bind button in the menu of your tx. Than you have to wait until the light stops blinking. Switch the tx off, switch the rx off.
Switch the tx on, switch the rx on.
26 Jul 2013 09:31 #12510 by vlad_vy
Replied by vlad_vy on topic How to bind LOSI Micro-Rally 2.4Ghz-BL
It's totally impossible, ground DSM2 protocol is different from air and marine DSM2 protocols.
You can use air DSM2 Tx only with 'marine' DSM2 receivers.
Time to create page: 0.382 seconds
