Custom switch widgits?
15 Jul 2013 18:15 #12255 by magic_marty
Custom switch widgits? was created by magic_marty
Is there a way to make custom switch icons/widgits where you assign them to the switch? Like if i am flying a Quad with "return to home" mode can i make it were when the the RTH switch is flipped it shows on the screen a icon "RTH" so i know the quad is in return to home mode?
thanks all...
  • rbe2012
  • rbe2012's Avatar
16 Jul 2013 05:37 #12260 by rbe2012
Replied by rbe2012 on topic Custom switch widgits?
Yes, you can paint your own icons (e.g. with GIMP as described somewhere in the forum) and store them in media/toggle3.bmp (each icon 32pix wide, 31pix high, Format 16 bit ARGB, more than one icon: place them in a horizontal line). You can select them as usual.
If you are Devo12 user the media directory is compiled in the devo12lib.dfu-file so you can add them only ad build time.
16 Jul 2013 19:51 #12272 by magic_marty
Replied by magic_marty on topic Custom switch widgits?
i have gimp but can't figure out how to add text ...so i need to do some more reading obviously ...
thanks for the reply..
  • rbe2012
  • rbe2012's Avatar
17 Jul 2013 06:14 #12281 by rbe2012
There is a tool in GIMP with the big "A" what allows you to write text in a new layer (select tool, select area in picture, write text).
17 Jul 2013 18:01 #12293 by magic_marty
Tried that and it lets me type but can't put it in the little box i want to...oh well it was a good thought but just a bit to over my skills at the moment.
Time to create page: 0.183 seconds
