- Channel mixup - (Using Devo7E, OrangeRX 4CH DSM2)
- bampi2k
22 Jul 2013 07:16 #12415
by bampi2k
Channel mixup - (Using Devo7E, OrangeRX 4CH DSM2) was created by bampi2k
Hello Guys,
First, i do not know if this issue is discussed/solved anywhere else. So if any one sees this and knows the post/thread that deals with the same issue, please post the link. And i am sorry in that case.
Here is my problem:
I am using a OrangeRX 4CH micro RX along with Devo7E (Deviation 3.0.0).
TX configuration is on MODE1.
It seems the ELEV and THRO channels have got reversed!(as if i were using a MODE2 or MODE3 TX)
The channel that is marked with ELEV on the RX is responding to the throttle stick movement. The channel marked with THRO on the RX is responding to the elevator stick movement!!
After initial investigation i believe something to be wrong with the TX, and DSM2 protocol since,and the clues to getting to a solution would be:
1. On boot it is checking for a safe value on CH1 (elevator channel).This problem does not exist in DEVO protocol, it checks safe value for CH3.
2. The throttle percentage display on the main screen seems to be proper. responding to the throttle stick (right stick in MODE1)
3. The RX works perfectly fine with the DX6i that i have.
Am I missing something here? Is there a channel mapping or something?
Regards,
Sourav
Here is my problem:
Regards,
Sourav
22 Jul 2013 07:37 - 22 Jul 2013 07:38 #12416
Replied by vlad_vy on topic Channel mixup - (Using Devo7E, OrangeRX 4CH DSM2)
After switching to protocol with different channels mapping you need to remap first 4 channels manually at Mixer page (change first 4 channels mixers to proper source) or load any template (it will remap channels automatically).
DSM2(X) protocol has different channels mapping (from default Walkera protocol):
Walkera
1 - Elevator
2 - Aileron
3 - Throttle
4 - Rudder
JR (Spektrum)
1 - Throttle
2 - Aileron
3 - Elevator
4 - Rudder
Futaba (Hitec)
1 - Aileron
2 - Elevator
3 - Throttle
4 - Rudder
Walkera
1 - Elevator
2 - Aileron
3 - Throttle
4 - Rudder
JR (Spektrum)
1 - Throttle
2 - Aileron
3 - Elevator
4 - Rudder
Futaba (Hitec)
1 - Aileron
2 - Elevator
3 - Throttle
4 - Rudder
Last edit: 22 Jul 2013 07:38 by vlad_vy.
- bampi2k
07 Aug 2013 08:28 #12805
by bampi2k
Replied by bampi2k on topic Channel mixup - (Using Devo7E, OrangeRX 4CH DSM2)
Thanks... been away from the PC for long... but thanks a lot for the help!
- carlnoki
02 Mar 2014 17:38 #21092
by carlnoki
Replied by carlnoki on topic Channel mixup - (Using Devo7E, OrangeRX 4CH DSM2)
just found this and just set the TX up for my Orange RX's.
Good info.
thanks
Good info.
thanks
Time to create page: 0.111 seconds
