Bind Devo 7E and Devo 10 to the same reciever
29 Jul 2013 17:55 #12601 by Xermalk
Hello
Is it possible to have a Devo 7E and a Devo 10 bound to the same DSM2 reciever?
I just received my devo 10, but it seems im going to have to go through the full bind procedure to get it to work with my rx. I though all the relevant bind information was stored in the model files?
I would love if i wouldn't have to go through all that hassle every time i swap between transmitters. My rx is stuffed fairly far into the frame so its a pita to get the wires out of it and then pulling it out.
31 Jul 2013 14:14 - 31 Jul 2013 14:16 #12645 by domcars0
Replied by domcars0 on topic Bind Devo 7E and Devo 10 to the same reciever
I think you have to use the automatic bind (not the fixeId).
[EDIT]Oups sorry, don't see that your RX is not a Walkera but a DSM2, so I've no solution.
Last edit: 31 Jul 2013 14:16 by domcars0.
31 Jul 2013 14:28 #12647 by vlad_vy
Replied by vlad_vy on topic Bind Devo 7E and Devo 10 to the same reciever
It's impossible, bind packet contains unique Tx ID.
31 Jul 2013 17:24 - 31 Jul 2013 17:25 #12651 by Xermalk
Replied by Xermalk on topic Bind Devo 7E and Devo 10 to the same reciever
Any way to have the same unique Tx ID on 2 different deviation tx'es?
Im guessing it should be possible with minor code changes?
Unless the tx id is stored inside the wifi modules, and are added there.
Last edit: 31 Jul 2013 17:25 by Xermalk.
31 Jul 2013 19:02 #12653 by RandMental
Replied by RandMental on topic Bind Devo 7E and Devo 10 to the same reciever
Xermalk wrote: Unless the tx id is stored inside the wifi modules, and are added there.
Yes it is
31 Jul 2013 19:33 #12657 by FDR
Yes it is
Partially true: the ID is indeed comes from the RF chip, but the fw reads it and sends out at binding, so in theory you could set whatever ID you like.
There was a discussion about that already...
While it has some security risk, it is doable: for example the tx's ID could be overriden with an optional ID from the tx.ini...
31 Jul 2013 19:33 - 31 Jul 2013 19:40 #12658 by Xermalk
Posted at the same time heh,
FDR, would it be much work to add that functionality?
Though i'd rather have it in the model file, then the TX ini.
Edit: actually that would be fairly bad for those that share confighs. Tx ini for the id and a on/off in the model ini would be best.
Last edit: 31 Jul 2013 19:40 by Xermalk.
31 Jul 2013 19:50 #12663 by FDR
I guess it's not that hard...
I wouldn't bother with it in every model config however. If you have two transmitters, set one of them to the ID of the other, and you can use those model configs on both of them, which share the same fixed id...
31 Jul 2013 20:09 #12668 by Xermalk
Would there be any issue if both tx'es were used with the same id, but different protocols?
Time to create page: 0.316 seconds
