DEVO7E Issue with USB Storage
01 Aug 2013 07:38 - 01 Aug 2013 07:39 #12686 by blackmoon
DEVO7E Issue with USB Storage was created by blackmoon
I'm using deviation-devo7e-v3.0.0-ddf6350.zip nightly
This is maybe an hardware issue of my devo7E, so I would like to know if anyone has the same problem to rule out a software issue.
When I go into storage mode by powering on while holding ENT key, windows shows me the "which action do you want windows to execute" for the usb storage in my devo.
Then all of a sudden the transmitter continues it boot sequence,the main page is displayed, and the usb storage is gone in windows.
This happens if a hold the switch and release it or even if I press it for 4 seconds or more.
I have to go trough the process 3-4 times to have the transmitter stay in usb storage mode.
Last edit: 01 Aug 2013 07:39 by blackmoon.
01 Aug 2013 07:58 #12687 by vlad_vy
Replied by vlad_vy on topic DEVO7E Issue with USB Storage
I have the same with Devo 8s.
01 Aug 2013 09:49 #12689 by blackmoon
Replied by blackmoon on topic DEVO7E Issue with USB Storage
Thx for the reply Vlad.
Do you think it's a deviation issue or mostly a hardware issue on the devo line side ?
01 Aug 2013 10:16 #12690 by RandMental
Replied by RandMental on topic DEVO7E Issue with USB Storage
I have not seen it on my Devo8 with probably 50-60 updates and refreshing the file system, but I'll see if I can duplicate it tonight.
Does it happen when you enable the file system through the screen without a power off/on cycle?
01 Aug 2013 10:26 - 01 Aug 2013 10:28 #12691 by vlad_vy
I don't remember it exactly, but I think at USB page all works fine. It has place at boot time with pressed ENT button. Quite frequently, after I see USB picture and release ENT button, Tx boot to main page. Seems, if I hold ENT button pressed quite long, Tx remains at USB mode.
Last edit: 01 Aug 2013 10:28 by vlad_vy.
01 Aug 2013 12:41 - 01 Aug 2013 15:28 #12692 by RandMental
Could it be Battery Voltage related?
My Devo8 is normally on-charge when I use the Flash Drive. I know PB stops writing to the Flash memory when the voltage is low to prevent corrupting the drive, may be there is also a check when in external (PC) access mode?
Last edit: 01 Aug 2013 15:28 by RandMental.
  • rbe2012
  • rbe2012's Avatar
01 Aug 2013 14:14 #12695 by rbe2012
Replied by rbe2012 on topic DEVO7E Issue with USB Storage
No problems with Devo12 (even if I release "ENT" after half a second...). But Devo12 is charged via USB.
I will test my Devo8 later.
01 Aug 2013 15:21 - 01 Aug 2013 15:29 #12698 by vlad_vy
I think this is due to ENT button contact chatter. I have this problem with any state of charge, with full charged battery or any other state.
If you press ENT button at USB mode, Tx will boot to main page.
Last edit: 01 Aug 2013 15:29 by vlad_vy.
  • rbe2012
  • rbe2012's Avatar
05 Aug 2013 05:39 #12766 by rbe2012
I am quite sure that this part is not under deviation control? If I am wrong, we could look for adding debouncing code.
05 Aug 2013 07:20 #12770 by vlad_vy
Now I think it related to ENT button contact chatter. I can't reproduce this effect stably.
05 Aug 2013 07:25 - 05 Aug 2013 07:27 #12772 by blackmoon
Yesterday I tried with the USB menu choice, I got the "press ent to turn the usb drive on" the TX stayed in usb mode until I pressed ENT again to exit usb mode.
The TX didn't boot to main page, I had to do an EXT to go back to the upper menu.
I'll try that for now on an report back, but it seemed more stable.
Last edit: 05 Aug 2013 07:27 by blackmoon.
05 Aug 2013 15:31 #12773 by RandMental
vlad_vy wrote: Now I think it related to ENT button contact chatter. I can't reproduce this effect stably.
I think Vlad is right, I could not reproduce it either on the screen or using the power-on ENT button sequence.
Adding a small (10nF) filter/debounce capacitor over the switch contacts or from the active contact to ground could help.
Time to create page: 0.087 seconds
