- Devo7e just loaded 3.0.0. How to bind to RX701?
- zbowman
01 Aug 2013 22:06 #12705
by zbowman
Devo7e just loaded 3.0.0. How to bind to RX701? was created by zbowman
New to the deviation tx firmware. It seems nice.
Have my model setup in the tx after updating the firmware. Everything seemed to go smoothly. Set the TX type to DEVO.
Not sure what needs done to get it to bind to my RX701 rx. Using it in a scratch build spitfire. Should be able to fly once I figure out how they bind.
Thanks for any help
Thanks for any help
- zbowman
01 Aug 2013 22:15 #12706
by zbowman
Replied by zbowman on topic Devo7e just loaded 3.0.0. How to bind to RX701?
I'll add that when I turn on my Devo 7e it does show an error of 'Bad/Missing Protocols' with just an OK button to remove it.
I assumed that was for the extra modules that could be used like frsky,etc.
- zbowman
01 Aug 2013 22:44 #12708
by zbowman
I should have read the 7e manual.
Moved the protocol folder onto my transmitter
Set the protocol to Devo
Opened the Fixed ID and deleted all numbers so it would be set to none which then auto-binds and then tried again. Bound instantly
Thanks for the nice new firmware
Time to create page: 0.308 seconds
