Beginner with Deviation - Questions
- jb57
02 Aug 2013 12:36 #12724
by jb57
Beginner with Deviation - Questions was created by jb57
I own both a Devo 7E and 10.
I cannot get the Walkera update SW (v1.7) to run on either of my PC, one is Windows 7 64 bit other is Vista 32 bit. The driver is installing correctly to recognize the transmitters, but the SW crashes. I've tried every combination of compatibility modes to get it run....including installing x86 drivers and running in XP mode....still DOA.
Here's the details of the error that I get:
Problem signature:
Problem Event Name: APPCRASH
Application Name: DevoDfuSe.exe
Application Version: 1.7.0.0
Application Timestamp: 50c93aa1
Fault Module Name: DevoDfuSe.exe
Fault Module Version: 1.7.0.0
Fault Module Timestamp: 50c93aa1
Exception Code: c0000005
Exception Offset: 0000b981
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 1033
Additional Information 1: f3a5
Additional Information 2: f3a550f0120a58c67111b1e6726efa50
Additional Information 3: dc75
Additional Information 4: dc7551f4409912cff7beeea5737703cb
Problem signature:
Locale ID: 1033
- Knowing Walkera's poor support / SW, is there a fix for this?
- Does the Deviation SW replace the need for Walkera's SW for firmware updates?
- Can you direct me to the right thread for this
info????
02 Aug 2013 12:52 #12725
Replied by FDR on topic Beginner with Deviation - Questions
Try an older DfuSe, like this 1.4:
www.derspielstein.com/soft_up/soft_file_1315373997456_en.zip
- jb57
04 Aug 2013 02:28 - 04 Aug 2013 03:37 #12748
by jb57
Replied by jb57 on topic Beginner with Deviation - Questions
Version 1.4 did not run either. I'm following the Walkera installation exactly. Pointing the driver update to the C:\Program Files\devention Upgrade Tools\Driver path instead of moving he inf and driver to the System32\driver folder.
I had Windows 7 run the compatibility test is suggested XP SP2 with administrator privileges....still did not run...same crash as in prior post.
Tried turning of my antivirus and run, no luck.
I've tried running in "safe mode" to prevent conflicts, still not luck.
I'm stumped.
FDR
I did installed the STMicroelectronics' DfuSe and it loaded perfectly and ran.
I didn't use it yet to upgrade any firmware.
I went to your page rc.fdr.hu/devo.php#technical_data
It says there that we can use the STMicroelectronics' DfuSe USB device firmware upgrade as in alternative. If so what are it's instructions for use the link on the aforementioned page is broken for the ST manual.
I'm stumped.
FDR
Last edit: 04 Aug 2013 03:37 by jb57.
05 Aug 2013 04:59 #12764
No you can't use the STM DfuSe for the fw upgrades, because Walkera does some additional encoding/decoding to the program in their update tool.
As a last resort vou can use the replacement upgrade tool written ny PhtacturedBlue:
www.deviationtx.com/forum/7-development/...-testers-for-usbcode
Time to create page: 0.207 seconds
- Beginner with Deviation - Questions
