Expert mode to standard mode
11 Aug 2013 15:08 #12909 by chrlsdim
Expert mode to standard mode was created by chrlsdim
if i pass from expert mode to standard mode the model is reinitialized...
it's not cool !! it's normal ?
regards.
11 Aug 2013 15:15 - 11 Aug 2013 15:16 #12910 by PhracturedBlue
Replied by PhracturedBlue on topic Expert mode to standard mode
It should only happen after you confirm the dialog box. do you not get the dialog? It is possible there is a bug in the logic that detects whether your model is compatible to standard or not, but I'd need to see a model.ini that has this issue, since when I try it, it works as expected.
But yes, the standard gui is not compatible with most advanced models
Last edit: 11 Aug 2013 15:16 by PhracturedBlue.
12 Aug 2013 21:28 #12933 by Xermalk
Replied by Xermalk on topic Expert mode to standard mode
PhracturedBlue, you might want to add a note about making a backup before swapping from standard to expert. In the dialog box that shows up.
  • rbe2012
  • rbe2012's Avatar
23 Aug 2013 12:19 #13182 by rbe2012
Replied by rbe2012 on topic Expert mode to standard mode
My opinion: it should be clearly referred to in the manual, but not in the dialog.
