Devo 6 died suddenly
- rossyan
13 Aug 2013 14:36 - 13 Aug 2013 17:45 #12944
by rossyan
Devo 6 died suddenly was created by rossyan
I bought a Devo 6 second hand and flashed it with deviation firmware 3.0. I was very happy with it and it died suddenly one day. When I turn it on, only the blue light briefly light up for half second then nothing happens.
I have fixed its battery leak problem following the online instruction and it worked without any problem for two month. I opened it to check for loose wire and everything looks fine.
I have always used regular AA battery and never used LiPo battery with the TX.
What could be the issue?
Last edit: 13 Aug 2013 17:45 by rossyan.
- rossyan
13 Aug 2013 17:54 #12950
by rossyan
Replied by rossyan on topic Devo 6 died suddenly
Another question. Does the main board take 5V power only?
I have some high quality vehicle phone charger which gives good 5V output. I can solder one inside the TX and use 11.1V LiPo battery as the TX power source.
- MatCat
13 Aug 2013 21:43 #12955
by MatCat
Replied by MatCat on topic Devo 6 died suddenly
Not exactly answering the OP, but as far as powering the TX goes I recommend a UBEC, I use one that is set to 6V and it works fantastic, use it with an 850ma 3 cell lipo, which knocks the pants off of AA batteries.
- rossyan
14 Aug 2013 01:47 #12957
by rossyan
Found the culprit - a bad power switch. Short circuited the switch and the TX turned on without any issue.
I destroyed a V911 TX and farmed the switch and RF module to do the repair and RF mod. V911 TX's switch appears to have better quality than the Devo 6's switch.
- rossyan
14 Aug 2013 01:50 #12959
by rossyan
Never thought of that before. Good idea and going to try it.
MatCat wrote: Not exactly answering the OP, but as far as powering the TX goes I recommend a UBEC, I use one that is set to 6V and it works fantastic, use it with an 850ma 3 cell lipo, which knocks the pants off of AA batteries.
- RandMental
14 Aug 2013 10:24 #12962
by RandMental
Indeed a great idea - just make sure the UBEC is a Switching type and not the linear versions, otherwise you will gain little from the extra voltage of a 2s or 3s battery
Replied by RandMental on topic Devo 6 died suddenly
rossyan wrote: Never thought of that before. Good idea and going to try it.
14 Aug 2013 10:40 #12963
Replied by vlad_vy on topic Devo 6 died suddenly
And it has beep low voltage alarm, othervise you take chance to get sudden Tx shutdown. Tx low voltage alarm in that case is useless.
- rossyan
14 Aug 2013 13:58 #12965
by rossyan
The problem comes back again. I replaced the switch and TX still won't turn on. I measured the connectivity of the switch with multi-meter and it works fine. I unplugged the switch from the main board and used a screw driver to short circuit the two pins in the switch plug socket. One out of five times it will turn on the TX.
It looks like the main board is very picky about the pulse from the switch.
Is there a way to fix it?
Time to create page: 0.509 seconds
- Devo 6 died suddenly
