DSM2 Sats channel mapping?
18 Aug 2013 17:35 #13030 by HeliIntervention
DSM2 Sats channel mapping? was created by HeliIntervention
I have a Devo 10 and 2 sats on a RoBird. I am using mode 2 channel one responds correctly on left stick. left stick controls rudder. no response to right stick aileron on channel 2 Ele on channel 3. can someone explain how to change the mapping order. I have tried switching stick modes because in some channel mapping it would change to the right stick!
19 Aug 2013 20:35 - 19 Aug 2013 20:35 #13041 by HeliIntervention
Replied by HeliIntervention on topic DSM2 Sats channel mapping?
That does not seem to be the issue. It does it on my Bx as well. Problem persist on both protocol's AR6200 DSM2 Sats & a Beastx. flashed back to Devo FW then flashed back to 3.0 same issue setup new models. I have wk 2601 & 2801 models that have no tail control channels mapped correctly.
Last edit: 19 Aug 2013 20:35 by HeliIntervention.
25 Aug 2013 17:57 #13274 by HeliIntervention
Can someone please send me an .ini file for either DSM2 Sats or a AR7200bx I'm using it on 450's.thanks for any help in advance!
25 Aug 2013 19:02 #13276 by Cesco
Replied by Cesco on topic DSM2 Sats channel mapping?
My pocketquad .ini file. Single 7ch DSM2 SAT.
27 Aug 2013 21:44 #13340 by HeliIntervention
Thanks,
I tried your file and I'm still not able to get it right.
throttle = throttle
aileron = no response
Elevator = no response
rudder = aileron
no response at all in right stick in mode 2. I am using a RoBird G31 FBL controller this should not be an issue though.
  • rbe2012
  • rbe2012's Avatar
28 Aug 2013 05:58 #13347 by rbe2012
Replied by rbe2012 on topic DSM2 Sats channel mapping?
Maybe a stupid question but have you checked in the channel monitor that there are values sent by the tx?
11 Mar 2014 04:21 #21443 by Rkozak99
Replied by Rkozak99 on topic DSM2 Sats channel mapping?
Hi...I'm have a similar issue...I get correct response on left stick but ALI movement only moves one servo (the left front) and the ALI servo has no movement. Elevator works fine and pitch as well, but no movement on right front servo.
Have you solved your issue?
11 Mar 2014 13:27 - 11 Mar 2014 13:32 #21453 by jazzjohn
Replied by jazzjohn on topic DSM2 Sats channel mapping?
These two work for my 2 Robirds. Model 9 correctly maps to a double Lemon satellite setup and model 10 maps to a single Spektrum satellite.
Edit: Model 10's name changed in the upload.
Last edit: 11 Mar 2014 13:32 by jazzjohn.
Time to create page: 0.794 seconds
