setting up a 7 ch airplane with dual aileron,flap
  • rbe2012
  • rbe2012's Avatar Topic Author
21 Aug 2013 14:29 #13105 by rbe2012
You should read the manual first and try to understand how deviation works. If you have worked through the manual most aspects will be clear.
To control two output channels with one stick you simply choose the same stick as input for both channels (or one inverted or scaled or with offset... the possibilities are great).
21 Aug 2013 17:47 #13129 by matrixFLYER
Replied by matrixFLYER on topic setting up a 7 ch airplane with dual aileron,flap
rbe2012 wrote: You should read the manual first and try to understand how deviation works. If you have worked through the manual most aspects will be clear.
Thanks, that fixed my problem!
Time to create page: 0.030 seconds
