Throttle Arming Sequence Possible?
- sllewji
21 Aug 2013 15:20 - 21 Aug 2013 15:24 #13112
by sllewji
Throttle Arming Sequence Possible? was created by sllewji
Using the current mixers, would it be possible to create an arming sequence for
the throttle channel?
i.e. :-
- when HOLD1 = 100 then CH3 = -100
- CH3 = -100 until (HOLD0 = 100 and LEFT_V = -100), then CH3 = LEFT_V
Or does this require a virtual 'sticky' toggle switch?
Apologies if this is already covered somewhere else - just point me in the right direction.
Ian
i.e. :-
Ian
Last edit: 21 Aug 2013 15:24 by sllewji.
- Hexperience
21 Aug 2013 16:58 #13123
by Hexperience
Replied by Hexperience on topic Throttle Arming Sequence Possible?
Search tab at the top, put in sticky, second result:
www.deviationtx.com/forum/how-to/1953-ho...-throttle-hold#11791
- sllewji
21 Aug 2013 17:27 - 21 Aug 2013 17:30 #13125
by sllewji
Replied by sllewji on topic Throttle Arming Sequence Possible?
Hi Hex,
Thanks for the pointer and apologies - I'm still finding my way around. I was searching for "throttle arming" not "sticky throttle".
I think that post ought to be made sticky itself
This is a trick that I'll ceratinly be using on all my models.
Ian
Ian
Last edit: 21 Aug 2013 17:30 by sllewji.
Time to create page: 1.085 seconds
- Throttle Arming Sequence Possible?
