Does Devo7e Antenna need to be outside Tx?
29 Aug 2013 16:16 - 29 Aug 2013 16:29 #13374 by sllewji
I'm going to be doing the "two-switch", "range extender", and "A7105 module" hardware mods to my Devo7e shortly.
Ideally I would like to remove the plastic antenna cover and replace it with a blanking plate - leaving the original antenna inside the Tx case.
As the A7105 antenna will be inside the Tx anyway, I'm guessing this won't be a problem - or am I wrong?
Ian
Last edit: 29 Aug 2013 16:29 by sllewji.
  • rbe2012
  • rbe2012's Avatar
30 Aug 2013 05:53 #13387 by rbe2012
Replied by rbe2012 on topic Does Devo7e Antenna need to be outside Tx?
I think if could even get better - in stock 7e the antenna points to the model (if you hold the tx like most people do). This is the direction where the signal strength is the most bad...
Keeping it inside the tx and arrange it in parallel to the front should improve the range. Make sure that no metal (or carbon ;) ) parts provide shadows.
30 Aug 2013 14:15 #13398 by sllewji
Replied by sllewji on topic Does Devo7e Antenna need to be outside Tx?
Thanks rbe,
I hadn't realised that it might be more efficient _inside_ the case
Ian
Time to create page: 0.493 seconds
