Help looking for a longer switch for throttle hold
06 Sep 2013 09:48 #13594 by matrixFLYER
I'm looking for a longer switch then the one that came with Devo10 radio for throttle hold.
My old DX6i had a long more easy to push switch. The Devo10 is shorter and harder to activate/deactivate.
Where can I buy it?
  • rbe2012
  • rbe2012's Avatar
06 Sep 2013 11:51 #13598 by rbe2012
This was discussed before. You should find it with "switch replace" I assume.
In general all standard switches (from electronic component market) will fit if you are willing (and able) to resolder the wires.
06 Sep 2013 12:22 #13600 by sbstnp
Or you could just get used to the current switch, change is good, keeps your brain in shape :)
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
06 Sep 2013 12:24 #13601 by matrixFLYER
Replied by matrixFLYER on topic Help looking for a longer switch for throttle hold
I think i will do this way, anyways people says that they got the long 2 position throttle hold switch for the DX6i from
www.radioshack.com/family/index.jsp?cate...ProdsPerPage=60&pg=1
Can someone help me to find it?
  • rbe2012
  • rbe2012's Avatar
06 Sep 2013 16:14 #13613 by rbe2012
Just from looking at the pictures I did not find any long switch. But those alike "SPST Flatted Metal Lever Toggle Switch" should fit. Just search one with a long handle...
(I would think the SPST line, also the NTE54 and DPDT lines should mechanically fit as replacement)
06 Sep 2013 16:17 - 06 Sep 2013 16:20 #13614 by matrixFLYER
I found this and should be perfect...except the crazy price :D
www.wowhobbies.com/walkeratransmitterhea...on-11mmhandle-3.aspx
I also asked HH how much for the TH switch of the DX6i :D :evil:
Last edit: 06 Sep 2013 16:20 by matrixFLYER.
  • rbe2012
  • rbe2012's Avatar
07 Sep 2013 05:56 #13624 by rbe2012
The price is not unusual in Germany if you buy at a hobby store. It will be much cheaper to get one from an electronic store.
07 Sep 2013 17:02 #13631 by Daryoon
HobbyKing has spares for their 9XR transmitter now. Among them are switches. Pretty inexpensive too IMHO. I believe they should work with the Devo.
08 Sep 2013 14:05 - 08 Sep 2013 14:06 #13649 by matrixFLYER
Daryoon wrote: HobbyKing has spares for their 9XR transmitter now. Among them are switches. Pretty inexpensive too IMHO. I believe they should work with the Devo.
There isnt' a 2 pos switch LONG.
Last edit: 08 Sep 2013 14:06 by matrixFLYER.
Time to create page: 0.890 seconds
