troublw with firmware
- liongera
27 Oct 2013 00:12 #15020
by liongera
troublw with firmware was created by liongera
Hello, help me please
I'm having problems after updating the firmware.
The problem is after binding the transmitter and the receiver (fixed ID)
The receiver does not receive a signal from the transmitter when i try start motors (Both sticks to the lower left and right position). The motors dont run.
In the original firmware is no such problem.
And another problem, when I back to the original firmware, the fonts after the firmware becomes unreadable. I donr know why.
Thanks for the answers
27 Oct 2013 06:38 #15025
Replied by vlad_vy on topic troublw with firmware
1. What is your model and protocol?
2. When you flash back original firmware, you need flash (Upgrade) firmware and library.
27 Oct 2013 08:11 #15027
Replied by rbe2012 on topic troublw with firmware
For your ID problem: as far as I know the fixed IDs from the Walkera stock firmware have to be reset in the rx (bind with deviation without ID), then set a new one with deviation.
- liongera
27 Oct 2013 10:33 #15031
by liongera
Replied by liongera on topic troublw with firmware
vlad_vy,
model: Walkera Devo 10
Protocol: DEVO
Yes I did as you say(you need Upgrade firmware and library).
But after the upgrade is what I see on the display:
s8.postimg.org/m2yt5yqyt/image.jpg
s8.postimg.org/py278ja4l/image.jpg
rbe2012,
maybe what you say, but
the problem is that the receiver is not to see the transmitter and constantly flashes red (signal detection)
Protocol: DEVO
rbe2012,
27 Oct 2013 10:50 - 27 Oct 2013 10:52 #15033
Possible you 'Upload' library, not 'Upgrade'. In that case you corrupt the library file, you need download fresh copy and do 'Upgrade'.
Try reset Fixed ID at Rx and clean Fixed ID at Tx, then bind. If connected, enter Fixed ID and bind.
Last edit: 27 Oct 2013 10:52 by vlad_vy.
27 Oct 2013 10:53 #15034
Replied by FDR on topic troublw with firmware
The fixed id implementation in deviation is the same as in the original devention fw, however you have to set that known id on the model setup page instead of the default 123456...
However the fixed id of the WK2801 protocol is different...
Time to create page: 1.288 seconds
- troublw with firmware
