Please help make the delay with the change of para
04 Nov 2013 06:19 #15310 by teremok
Hello, how to do it:
I switch the switch:
- there is a signal to the receiver (all standard)
- off pitch (throttle 0%)
- after 1 second, turned pitch (throttle) 70% (any number greater than 50%)
For all of this made ​​the switch only 1 switch.
This is to autolevel FBL brain / ikon / track.
Thank you very much!
04 Nov 2013 06:28 #15311 by FDR
I don't really understand, what do you want to achieve...
Could you explain more?
...or you can probably send vlad_vy a PM in russian...
04 Nov 2013 06:46 - 04 Nov 2013 06:47 #15313 by vlad_vy
Russian don't help, I've read this at russian forum.
As I can understand:
1) switch as the source for channel (e.x. AUX2) = autolevel signal,
2) the same switch used for pitch = 0%,
3) 0.5-1 second later, pitch restored to 50-70%.
Last edit: 04 Nov 2013 06:47 by vlad_vy.
04 Nov 2013 08:35 #15320 by FDR
vlad_vy wrote: Russian don't help, I've read this at russian forum.
Still not clear...
Do you mean, that there is a switch to control something, but when it is switched it should set an other channel to a specified value for some time, but don't effect it after that? Should it set that value when it is changed to any direction, or just whet it is turned on?
You could use something similar to Fabien's sawtooth generator, and form the one time only started saw to a switch value:
www.deviationtx.com/forum/7-development/...rs-to-channels#13834
04 Nov 2013 09:32 #15321 by teremok
One value of the channel is replaced by another, pauses, and all this one switch.
Time to create page: 0.216 seconds
