Toggles for Devo12S
07 Nov 2013 05:43 #15400 by Pattaya01
Toggles for Devo12S was created by Pattaya01
I think I have asked this before, but maybe this could be done someway, somehow.
For all Devo TX's, except the Devo12S, it is possible to have your own toggle icons.
Could it be done for the Devo12S as well?
Since I am flying with APM 2.5 and other Flight controllers, I would like to have toggles like "RTL", "NAV", "CIRC", etc.
I did design all of them, but can only use them in the emulator... :(
  • rbe2012
  • rbe2012's Avatar
07 Nov 2013 07:07 #15406 by rbe2012
Replied by rbe2012 on topic Toggles for Devo12S
This is because the "media" folder is not in the file system but in the library. To use your own toggle icons you have actually to build your own library containing a file "media/toggle3.bmp" where you put in your own icons.
I have a solution for this and opened an issue in PBs repo some time ago (#406 in combination with #405), but it is not yet processed...
If you feel this to be an error place an issue in my repo and I will fix it (since we only fix issues for 3.1).
  • rbe2012
  • rbe2012's Avatar
07 Nov 2013 07:16 #15407 by rbe2012
I think I have improved something else for Devo12 users, but I have to search where I did this: in the media folder there are twi ini-files (config.ini and sound.ini) which should be user-changeable too. They both need only little space.
I have a solution lying around where those files are searches in a folder in the USB filesystem and is not found, those from the library are used.
07 Nov 2013 07:50 - 07 Nov 2013 07:51 #15408 by Pattaya01
Replied by Pattaya01 on topic Toggles for Devo12S
Good idea. Please add toggle0.bmp, toggle1.bmp and toggle2.bmp. My dream will come true :)
Last edit: 07 Nov 2013 07:51 by Pattaya01.
  • rbe2012
  • rbe2012's Avatar
07 Nov 2013 08:16 #15409 by rbe2012
toggle0, 1 and 2 are fix - users shall not change them. All individual icons go into toggle3.bmp.
07 Nov 2013 14:32 #15413 by Pattaya01
Sorry, didn't know that. I modified them and it worked. Never tried a toggle3.bmp
08 Nov 2013 01:31 #15431 by Pattaya01
Update:
RBE2012 posted version 3.1.0, Beta 10 which solves this issue:
After installing this new firmware and the LIB, put the TX in USB mode and create a new folder "mymedia". You can then put your toggle3.bmp here and the toggles will be displayed when you edit.
Thanks!!!!
Attached are my own toggles which you can try.
Time to create page: 0.398 seconds
