Real Flight and the Devo 12S
- ave1
14 Nov 2013 15:24 #15571
by ave1
Real Flight and the Devo 12S was created by ave1
Can someone comment on how to use the Devo 12S as the controller for a flight sim program? Is there a technique or procedure to use the devo 12 a the TX for "Real Flight" flight sim? Has anyone done this?
Thanks for reading and I hope someone might reply, please?
14 Nov 2013 15:42 #15575
Replied by FDR on topic Real Flight and the Devo 12S
Simply make a new model with PPM protocol, and use your PPM-USB dongle to connect it to the PC...
14 Nov 2013 19:35 #15585
Replied by rbe2012 on topic Real Flight and the Devo 12S
Or you can create a new model with USB HID as protocol and connect the tx directly via USB - tested with Windows and good results.
14 Nov 2013 19:40 #15586
Yep, but I've never tried that, because the placement of the USB plug is not comfortable on the DEVO 8...
14 Nov 2013 20:59 #15588
...as it is on Devo12. But works.
- Hexperience
15 Nov 2013 10:57 - 15 Nov 2013 10:58 #15600
by Hexperience
Replied by Hexperience on topic Real Flight and the Devo 12S
For real flight you have to connect the trainer port to the real flight controlled. I do it when my daughter flys the blimp and I fly a paintball plane.
Real flight 7 now has a dongle so you don't need to use the interlink as the dongle.
Last edit: 15 Nov 2013 10:58 by Hexperience.
- ave1
17 Nov 2013 07:11 #15639
by ave1
Replied by ave1 on topic Real Flight and the Devo 12S
Thank you all,,,,, as always and WOW!!! What a difference flying with my devo 12 instead of the TX that came with real flight.
thanks again.
And, would anyone know how the reset button is mapped? Lots of crashes in real life or real flight
TY
thanks again.
TY
Time to create page: 1.091 seconds
- Real Flight and the Devo 12S
